Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
My blanco single handle faucet leaks from the bottom of the housing below thelever handle. How do I remove the housing to see what the problem is or to replace an o ring or washer to stop the leak?
It is a Blanco Classic SIngle Handle faucet with pull out spray. It only leaks when the faucet is turned on.
4 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
Dplumber
  • 119 Answers
SOURCE: i have a single handle blanco classic that is
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Posted on Nov 07, 2010
  • 8 Answers
SOURCE: leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Posted on Mar 11, 2012
Leaking blanco single handle faucet with sprayer
Mar 11, 2012 | Blanco Plumbing
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
The faucet leaks where the spray hose attaches to the spray head. Model 157-074r-st. The problem occurs when water is turned on. If the spray head is in the handle, water leaks below the sink. If the spray...
Yes the leak is the washer. You can get a new washer at any hardware store. Just take the damaged washer with you and have someone at the store help you.
Here is the washer size according to the manual 20X12X2.5
Page 2 of the link below.
http://www.blancoamerica.com/SPECIFICATIONS/157074R.pdf
Feb 27, 2011 | Blanco Classic Single Handle Faucet with...
I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
How do I remove the bonnet nut from a blanco 1-handle faucet (like their "classic" model?
If you mean the top faucet handle, there is a small round plastic cap. You need to remove this and then remove the grub screw, handle will then pull off. Hope this is what you meant, if not post again. Thanks Paul.
Aug 30, 2010 | Blanco Classic Single Handle Faucet with...
The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
Hope this helps
Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
May 30, 2009 | Blanco Classic Single Handle Faucet with...
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
252 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
