Question about Rancilio Silvia Espresso Machine
Water does not heat
All lights are functioning (on button, steam button, etc.) but the heater is not functioning at all. Could this be an internal fuse or the element burned?
Yes there is an internal thermostat high-heat cut off. Take the top off your machine. There is a reset button on the front side of the boiler tank about third of the way down.
Posted on Nov 02, 2008
Heater wont stay on banging noise
Banging noise is never a good thing on a heater!
Cause:
  • Very low water flow thru heater
  • Calcification of internals / heat exchanger
  • Liming of internals in heat exchanger
Steam used to move giant monsters of a train across country, you have steam being generated in your heater, that's causing the bang and probably some rockin' & rollin' of the heater itself?
You should probably have a service tech look at it.
May 29, 2015 | Pool & Spa
What function does ignitor control panel serve
If you are talking about a heater.... ???
The ignitor will ignite the raw fuel that will start to heat: water, area, etc.
The Control Panel is the portion of your appliance that will have buttons & knobs to adjust temperature, jets, mode, lights, etc.
Sep 01, 2014 | Pool & Spa
Hayward 100 pool heater shaking
Not enough water flow!
Either a
  • bypass valve is open all the way, and reducing water flow into heater
  • Worn/broken internal bypass - unitherm governor
  • Blockage of some sort reducing water flow, in circulation line
When something like the above is present, the minimal water flow, gets super heated really fast when heater is on and firing! So hot in fact, that the water turns to Steam Instantly!
and the steam is a very Volatile substance! Remember? It was once used to move Locomotives!
get this fixed asap!
call a pool / spa professional for assistance in evaluating your next step.
Good Luck.
Jun 23, 2014 | Hayward Pool & Spa
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
I put water in it but steam isnt coming out
Faulty heater element. If you have had it for awhile that could be the problem. If it has electronic controls it is possible that the heater button is not functioning but my guess is the heater element especially if it is not getting hot.
Mar 25, 2012 | Sunbeam Humidifiers
The indicator is flahing as to say it is heating up the water but continues to do so and never heats up
What kind of Vacuum has a water heater in it?
That is a new one-- unless we are talking about a steam cleaning machine?
Tell us more about the machine, and if you can see where the Heater is?-- and the power to it, etc., etc.
Dec 27, 2010 | Vacuums
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Rancilio Silvia Espresso Machine Logo
174 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
