Question about Brother LS-1217 Mechanical Sewing Machine
Brother ls 1217 - needle continuously hitting foot and plate and breaking
In sewing, the needle continuously hits the face plate, or the foot and breaks. It is the correct needle, in the right way, same with needle position and foot position
  • Brother Master
  • 7,365 Answers
It sounds like the machine is out of time, & needs to be serviced
Posted on Feb 24, 2012
  • 23 Answers
SOURCE: the thread on the brother sewing machine keeps breaking when the
You may have a snag on the plate. And that means a new one. Just one possibility.
Posted on Mar 08, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: WHAT NEEDLES FOR SEWING LEATHER ON A LS 1217
The WEDGE POINT NEEDLE, which is designed for leather and vinyl, easily pierces these fabrics to make a hole that will close back upon itself. This eliminates unattractive holes in the garment, and also reduces the risk of the stitches tearing the fabric. The wedge point needle comes in sizes 11 to 18. The size 11 needle is designed for soft pliable leathers,while size 18 is designed for heavy or multiple layers of leather or vinyl.
Posted on Feb 08, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
JeremySew
  • 65 Answers
SOURCE: I need needles that can sew leather on the brother
We have those needles available here:
Schmetz Sewing Machine Needles For Leather
Posted on Jun 27, 2009
  • 1126 Answers
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Posted on Sep 17, 2009
Broken needle
ck the alignment of the foot plate (under presser foot) if needle rubs this plate it will break every time
Jan 21, 2016 | Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
My brother ls-1217 breaks needles, almost like it is out of alignment
Are you inserting them flat side facing away from you and making sure that they are inserted all of the way up? Make sure that your needles are not too long, ie. Singer. Check your tension and that you have the right needle for the job, as in denim use a heavy needle like a 14 or 16. Other than that it could be the timing which unfortunately needs a professional to fix.
Mar 19, 2011 | Brother LS-1217 Mechanical Sewing Machine
When I sew the needle hits the pressure foot. I think there is a problem like the shaft that the needle attachs to might be crooked and then it hits the pressure foot it won't go into the hold.
Your needle is probably bent, put a new needle in and make sure that you insert it with the flat side facing away from you. If, you do not have a manual, go to brother-usa.com and download one for free
Sep 09, 2010 | Brother LS-2125 Mechanical Sewing Machine
My needle keeps hitting the plate and breaking. How do I fix this?
Take the needle plate off and see where it needle is connecting with the bobbin. The bobbin case may not be in place and this is what the needle is hitting.
Feb 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    * When you insert your new needle, make sure it’s positioned correctly (usually with the flat side
    away from the bobbin, but consult your manual), that it goes all the way into the holder, and
    that the screw is securely tightened.
    If this doesn’t seem to be the problem
    * Check your pressure foot
    Make sure it’s attached securely.
    * Change your pressure foot
    Your pressure foot may be bent, causing your needle to hit it.
    * Don’t sew over pins
    A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
    * Don’t pull your fabric as you sew
    You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
    * Check your needle plate
    Make sure it's securely in position.
    * Change your needle plate
    If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
    sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
    * Check the position of your needle
    Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits plate and breaks or bends wont line up
If your needle is hittle the face plate, then it is out of time.. I would take it to your local repair center.
Apr 24, 2009 | Brother LS-2125 Mechanical Sewing Machine
What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Feb 09, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
221 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
