Question about Acer Office Equipment & Supplies
How to clear paperjam in acer monitor a 231h - Acer Office Equipment & Supplies
    Top Expert:
  • Acer Master
  • 1,575 Answers
Hi
Try turning it off and on.
Disconnect everything and connect again.
Posted on Feb 23, 2012
Paperjam in a hp photosmart c6380 all in one , how do I open to clear out paperjam ?
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Clear Paper Jam
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6380 All-In-One InkJet...
Every page i try to print is says i have a paperjam clear the jam and press enter so i clear the jam and press enter nad it prints and then says exactley the same with every page i try to print and there...
First, lift the top of the printer up past the sensor. This usually resets it or try turning it off, waiting a minute or two and then turning it back on. If this doesn't clear it and it the paper doesn't move through the printer straight, there is a small torn bit of paper somewhere that must be removed. Good Luck!
vicki.velaz
www.togohair.com
Hair, ready to go, ready to wear!
Sep 21, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Jan 15, 2010 | Epson Office Equipment & Supplies
Printer epson r230 paperjam
Indikator paper jam di status monitor bisa berarti benar-benar paper jam atau carriage problem. Coba dibongkar dulu printernya, mungkin ada sesuatu yang nyangkut pada paper feeder, bersihkan sekalian paper sensor pada paper feeder. Kemungkinan kedua adalah problem pada carriage atau bisa jadi pada chip di ink tank. Coba dulu ganti chip pada ink tank dengan yang lain ( yang baru atau yang arc). Salam dari Arema
Dec 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
My acer monitor image is faded and washed out
Adjust contract and luminosity: decrease contrast, see how it goes.
ACER monitors tend to have control settings that are out of the range for proper viewing.
Jul 15, 2009 | Acer X191WSD Monitor
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
Lexmark x215 paperjam #2
The exit sensor is defective if the paper has left the printer
completely but it appears
paperjam #2.
Once the paper has left completely, the exit actuator
must return to the original position to close photo sensor. Sometimes takes
more time than it had and it does not return.
The actuator can be deformed by the temperature.
Sep 23, 2008 | Lexmark X215 MFP All-In-One Laser Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
26 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
