Question about Acer Aspire 5315 Notebook
Can't find mac address on my acer to connect to wireless network at work
It connected fine at my friends wireless, and also two others, but here at work it won't accept my mac address. what else can i try or is there another mac address i need?
  • 1 more comment
  • fire_wolf71 Oct 27, 2008
    somebody help me please!!!
    ??? anyone??? so much for helping, the experts hiding???
  • fire_wolf71 Oct 28, 2008
    thank you, the problem was they were adding the wrong address to the work wireless system, thank you, I am up and running now! have a great day Drlalitv!
  • 488 Answers
I think the wireless at your work filter computers based on their MAC address as a security measure hence you are unable to connect..
to find your comp's MAC address follow this:
  • From the Start button select Run
  • In the box which appears type cmd and click OK
  • A new windows will appear - at the prompt type ipconfig /all
  • The MAC address will be referred to as the Physical Address and is made up of 12 characters e.g. 00-D1-AB-F2-G3-89
    You will have a separate MAC address for your wireless card and your Ethernet card. Make sure you use the correct one
  • do ask the admin of your work wireless system to add your comp's MAC address so that you are able to connect..
    am no expert but love to help out...hope it helps you...all the best!
    Posted on Oct 28, 2008
    • Lalit Varadpande
      Lalit Varadpande Oct 29, 2008
      am glad the problem got solved!have a great day!
    Wireless connection fails on acer E1-571
    Wireless problems can have various causes. Do other devices in your network work fine (other notebooks, smartphones)? And have you tested your Acer in other networks, like in a friends house, etc? If your notebook fails anywhere you use it, it may have a faulty wireless adapter (altough that's very rare). I would try to remove and reinstall the wireless driver and if that don't solve it, reinstall the OS (you could also have a virus problem). If the notebook works fine in other places, it could be your wifi router. Try turning it off and on.
    Dec 19, 2017 | Acer Aspire 6930-6771 Laptop
    My acer aspire 5517 laptop came with a built-in wireless card. It works fine at home with my Belkin router, however, I cannot connect outside of the house to other networks. Currently I am away at a...
    Your friend's network SSID (the name of the network) may be hidden. Ask your friend what the name of her network is, then enter that in manually and try to connect.
    Mar 05, 2011 | Acer Aspire 5100 Notebook
    Hi; We have guests that want to access our home wireless network. When trying to connect to our network........... they see a list of available network and when they select our network it does not ask...
    Have you go MAC address filtering enabled, if so you will need to add the MAC address to your wireless router's MAC address table.
    It is very difficult to diagnose the problem without knowing your wireless router's configuration and the wireless card configuration in your friend's computer.
    The easiest way to give them access is to use a LAN cable, provided you have spare LAN ports on your wireless router.
    Aug 09, 2010 | Arris SURFboard SBG900 Wireless Router...
    Any new user is rejected by the router.
    Please check your MAC address permision in your linksys router's.
    if you disable that MAC address permission require or MAC address authentication require, your friend will be able to connect to your router.
    Mar 30, 2010 | D-Link DIR-625 (790069292637) Wireless...
    Can't connect to friends network
    They are four reasons why your wireless would say "acquiring network address" and later changing into "Limited or no connectivity"
    1) Invalid WEP/WPA Encryption key.
    2) Mac Filtering, Your friends might have disallowed the mac address of your laptop or he it might be filtered.
    3) Short IP range mentioned on the router (May your friend has specified a short ip address range for DHCP)
    4) Invalid configuration for wireless on Windows Vista
    To this problem, do this on your laptop
    1) Start >> Control Panel >> Network and Sharing Center (Classic View) >> Manage Wireless network>> remove the wireless network by clicking and then right clicking on top of it and remove.
    2) Now try to connect again to the wireless network, reenter the key and that should do it.
    If this doesn't work, then probably you have to ask your friend about the 2 and 3 possible cause listed above.
    And Thanks.
    Mar 10, 2010 | Westell Wirespeed VersaLink...
    Used to have 2 computers working with our wireless router. One was directly hooked up with an ethernet cable, the other was wireless. I'm now trying to have two computers hooked up wireless from network...
    Perhaps you turned on MAC address filtering in your router's wireless security settings? It's a pretty good security measure for not allowing unwanted visitors to try hooking up to your wireless internet connection, so it might have been recommended.
    Go to your router's configuration and see if MAC filtering is turned on. If it is, you have to add your second computer's wireless card MAC address to the "allowed" list.
    Your card's MAC address is sometimes written on it, but it's simpler to go to command prompt and type "ipconfig /all", which will show you details about all the network devices present in the system. Find the wireless card and note the MAC (physical) address. Note: in windows the address has a "-" dash as a separator, whereas normally a ":" colon is used as a separator and this is usually the way you have to enter it.
    Oct 24, 2009 | Computers & Internet
    Mac OSX 10.5 doesn't seem to work with Belkin model F5D7230-4
    I get the feeling it is a security problem on your wireless access point. Try turning security off temporarily and see if the problem goes away.
    The fact that you can connect to other networks tells me that your mac book network config is ok.
    The reason the manual ip configuration doesn't work is because wireless connection connection has not succeeded. Kind of like not having the cable connected and expecting to find your DHCP server.
    One thing that comes to mind and drove me completely insane once is your wireless network name (ssid) is case sensitive. So homenet is different from Homenet for example and you won't get any decent error messages.
    With the security make it as simple as you can then slowly turn stuff back on (WEP and MAC filters for example) until it breakes again. Then you will know where your problem is.
    Hope this helps.
    Aug 16, 2009 | Belkin (F5D5231-4) Router
    Router won't connect to the internet
    I managed to figure it out. I had to clone the MAC address to get the router to connect to the Internet.
    I still have another problem though, my laptop still won't connect to the router. I'm using Vista, is this a possible network adapter issue? My laptop is fine at connecting to other wireless networks round my friend's houses/libraries...
    Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
    XBOX 360 not connected to wireless connection on Linskys WAG54G2
    You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
    Jan 06, 2009 | Computers & Internet
    New HP laptop will not connect to wireless secure network
    Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
    Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
    Acer Aspire 5315 Notebook Logo
    6,944 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
