HP will not print.It printed the test sheet. - Office Equipment & Supplies
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If it printed a test sheet, then the problem is in your program..
go to your printer and faxes folder, (same place as youfound the print test page)
set the HP printer to Default
Try to print from Word or Notepad, when the printer select window pops up make sure the HP is showing, and selected.
If you have more than one printer installed on your Computer, but only one printer, delete all the printers you are not using..
Posted on Oct 28, 2008
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 1350v prints a test page every time I turn on the printer?
Bet you recently replaced a print cartridge!
That model of printer recalibrates after any cartridge replacement.
Let one of those sheets print out in full. Read what is on the sheet. Place the sheet on the scanner
and press the button that the sheet indicated to be pressed. The printer will go through a alignment
cycle then quit. Once that is finished you should not have to do anything till the next time your change
a print cartridge.
Mar 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
My printer is printing big print and backwards on paper I tried to print a test sheet and it will not print
reinstall your print driver, this is a common problem with the hp universal print driver.
Jul 09, 2009 | HP Office Equipment & Supplies
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
Printing
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Jan 09, 2008 | HP PSC 1350 All-In-One Thermal Printer
jasbo
jasbo
