What are bands v-l, v-h and uhf on coby tv? - Televison & Video
Why will my tv not tune in bbc chanels
HI. It might be that your set is not equipped for S-band reception.
Some channels are in this S-band. Sometimes, you must choose between H/S band scanning. (The H stands for the normal VHF-UHF channels 2-62. )
Oct 12, 2014 | Bush Televison & Video
Why will my rca trflat not go past cannel 69
Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Oct 03, 2014 | Televison & Video
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
Digital or Analog tuner
Hello
Your Apex TV model have the tuner which is capable of receiving
VHF 2~13/UHF 14~69/CABLE TV: MID BAND(A-8~A-1, A~I)
SUPER BAND(J~W)
HYPER BAND(AA~ZZ, AAA, BBB)
ULTRA BAND(65~94, 100~125)
If the signal of your cable provider do not have in these ranges, you must have toconnect a converter.
http://www.dataentryjobs.us/67948.html
Feb 09, 2012 | Apex Digital PF2725 27" TV
No uhf band signals
Possible that the TUNER has failed as the UHF band is not working. so it will be important to check the switched voltage onthe UHF pin of the TUNER to confirm that power is received .
If so the tuner must be changed.
Apr 11, 2011 | Televison & Video
I Have a tv sony kv m1400, but i don't have the user manual,so i don't know how to tune the tv.
1. Press and hold down the [White Arrow Up] 'shift' button.
2. While held down press the UHF tuning button (symbol for button is ->).
3. Press + or - to tune up or down the UHF band as required, until the required station is reached.
4. Select a spare Channel Position.
5. Press [Arrow Up] & [UHF Tuning ->] buttons again to store and exit tuning.
You must use the remote control. No tuning is available on TV.
Feb 09, 2011 | Sony Televison & Video
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Local channel went digital, lost signal.
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
Feb 20, 2009 | Televison & Video
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
