My TV takes about 15 minutes to start playing.
And it only starts to completely play after a few plug and unplug cycles. The first 5 minutes is just silent power on. The it starts buzzing. Then the buzzing continues to get louder and is joined with a machine type sound for about 10 minutes. When it gets as loud as it will go, intermittent words will start. When the words start flowing as loud as they will go, I unplug it (because during this time the controls do not work). If the sound comes on normal after plugging in and the controls work then it will play. If not then it must be unplugged and plugged in again until the sound is normal. Usually this takes about 15 to 20 minutes. What could be causing this?
  • Jerad Sanders Feb 24, 2012
    This is a Sanyo CLT 1554-02 TV. I replaced the Mainboard and the Backlight board. It did not help.
  • Jerad Sanders Feb 25, 2012
    I narrowed the problem down to the TFT Display Drive Circuit. When I unplug it, it starts and plays. However no picture. Thanks Rocky for your comment. Interliquidparts does have a screen for it.
    Sergeant:
  • 302 Answers
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
Testimonial: "Yes"
When turned on box will only show menus and will not play TV or recordings. It gives the impression that it is trying to play in the background
i have ATT Uverse. Any problems I have had are usually solved by resetting the box. Press and hold the power button on the box until it shuts off-usually 5 seconds or so. Wait 3-5 minutes and power on. It takes a bit to reset. If that doesn't work, unplug from power supply completely. Wait 3-5 minutes. Plug back in and power on. If that still doesn't help, call ATT. The can do remote reboot, but, you will lose all recordings stored.
Sep 29, 2014 | Televison & Video
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
