Question about Keurig Platinum B70 Coffee Maker
Having trouble with my keurig b70 platinum water pump is laboring to push water thru to brew coffee
Water pump is making a loud noise when pushing water thru to make a cup of coffee & it takes longer to brew acupof coffee
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 3600 Answers
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
Posted on Aug 26, 2009
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
I purchased a B70 Keurig brewer less than a year ago and now it will not pump water.
That happened to mine. The pump broke. They sent me a new one at a "discount" but now after 2 months I have issues with this one. Can someone PLEASE make a coffee machine that will work? Preferably one NOT by Keurig that uses the K cups and the K cup you can use your own coffee in?
Oct 22, 2011 | Keurig Platinum B70 Coffee Maker
When I push the "brew" button, it makes noise like
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 27, 2011 | Keurig Platinum B70 Coffee Maker
I just descaled my coffee maker and now it doesn't make a whole cup, it says ready to brew, push the button and nothing happens, it shuts it's self off which it never did before. It makes a sound like it...
After the pump fills the keurig and a sensor detects the proper fill level, a valve closes and a 12Volt air pump turns on and pushed the water out of the internal resevoir to the head of the unit.
My B70 air pump siezed up.. (actually formed rust in the friction bearing). I had to take the back off and the pump is located behind the water resevoir. had to remove the pump and test it with a 12Volt power supply.. it didnt spin... so I disassembled the air pump and found the shaft stuck with rust .
Used "Kroil" or you can also use WD-40 on the shaft to free it up... re assemble the pump and re-solder the wires back tp the pump...
worked for me.
good luck.
Apr 17, 2011 | Keurig Platinum B70 Coffee Maker
My Platinum Keurig says it is ready to brew but nothing happens. I have cleaned out any coffee grounds.
My B70 has worked good for about 6 months. Lately it won't brew a full cup of coffee or water for that matter. I have run Limeaway, and also vinegar throught it but nothing works. It seems to me the pump is too weak to make coffee before an apparent time-out occurs.
Dec 15, 2010 | Keurig Platinum B70 Coffee Maker
Our Platinum Keurig will not pump water. The motor makes 3 kind of grinding noises and then silence. I have cleaned out the jet with a pin, so it is not that
there are two needels. one enter the top of the KCup and the other the bottom.
Aug 20, 2010 | Keurig Platinum B70 Coffee Maker
B70 goes on brew cycle, but will not push the water thru..seems like a problem with a pump
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Aug 19, 2010 | Keurig Platinum B70 Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
296 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
