Question about Samsung ML-1640 Monochrome Laser Printer
Samsung ML1640 keeps giving orange led and "Paper Jam in tray1"
Samsung ML1640 keeps giving "Paper Jam in Tray 1" error , everytime i want to print something. There is no jammed paper . If i take out the papers in tray 1 , the led becomes red , and after i put the paper back , the printer prints the job. Sometimes , if I put my hand inside the tray , and shake it , it print`s without any problem , no orange led , the printer feeds normaly with paper . I`ve take apart the hole printer , i`ve cleaned all the sensors for dust .. Don`t know what to do next. I think it`s an calibration issue. Do you have a clue in how to solve this ??? It`s very frustating !! Thanks in advance !!!
mdsaeed67
  • 849 Answers
SOURCE: fake paper jam
the roler, which picks the paper need to clean, try it
Posted on Oct 28, 2008
SOURCE: Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Posted on Apr 18, 2009
  • 220 Answers
SOURCE: samsung ml-1710 printer continues to jam paper;
pickup roller and seperaion pad req changing
Posted on Jun 22, 2009
tim30921
  • 6 Answers
SOURCE: Samsung CLP-300 click print and it starts to try
clean the rubber roller that pulls the paper from the tray with alcohol
Posted on Jan 10, 2010
ic0729
  • 212 Answers
SOURCE: samsung clp 300 won't pull paper out of paper tray
I understand the rollers are clean but are they viable to pick up single sheets. I dont think it can due to no matenance to the rubber on the rollers themselves.
Go to fixyourownprinter.com and purchase the "rejuvination roller" jar. With this product, you must use a qtip and dip some of the solution on it. Then rub down all rubber rollers and let it sit dry for about 14 minutes. After that, you can do a test and you will see that the rollers gained their feel to print single sheets again or pull out paper again
Posted on Mar 05, 2010
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
Hi i have problems with my 7502 gestetner nrg photocopier
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Feb 23, 2009 | Gestetner DSm618 All-In-One Printer
Error Jam0 in tray1
GO ON LINE TYPE IN MANUFACTURE NAME,MODEL#, ERROR MESSAGE AND ENTER KEY LIKE THIS:
CAMSUNG CLP-500 LAZER PRINTER ERROR MESSAGE JAM0
ENTER
ROD
Feb 09, 2009 | Samsung CLP-500 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Jun 02, 2008 | Office Equipment & Supplies
Samsung ML-1640 Monochrome Laser Printer Logo
1,431 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
