Question about NetGear WGR614 Router
Wireless router for new laptop does not work after erasing recent activity
My netgear was working with my gateway laptop, until i had anothe problem and tech support had me back up in time and it erased recent activity including the setting up of router... that is only a guess as to the problem ????????????
When i use the cd at the end it asks for a password and that does work ?
also i don't know what it means to power cycle the router for about 30 seconds
Posted on Oct 28, 2008
    Genius:
  • 1,269 Answers
Try to setup the router first using the setup CD that came with it. Power cycle the router for about 30 seconds after that.
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
Can you help me configure my netgear router? I cant seem to connect to http://192.168.0.1
you can try typing in your browser address bar www.routerlogin.net then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be 192.168.1.1 this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
Jun 21, 2010 | NetGear DGND3300 RANGEMAX DUAL BAND...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Toshiba Laptop builtin wireless modem can't find any network
If the laptop is 3 years old then it probably requires a chipset update. Goto intel's website and use the driver update utility. If this does not work then your wireless connection may be broken. You can buy a wifi USB card for less than £10 if you shop around. Good luck
Jul 23, 2009 | Computers & Internet
Wirless network - laptop
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Jun 25, 2009 | NetGear WGT624 Wireless Router
Wireless router not working.
Power cycle the modem/router, which ever it is, or both.
Unplug the power, let it sit for about 30 seconds, plug it back in and wait til all the light stop flashing. Internet light may flicker with activity.
May 31, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Internet connnection
Access your wireless router by typing it's ip address in your browser. Log in and change your netkey password.
May 23, 2008 | NetGear WGR614 Wireless Router
My laptop cannot connect to internet
check your ip address and default gateway are correct
Mar 20, 2008 | Computers & Internet
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
NetGear WGR614 Router Logo
24 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
