Question about Compaq Presario 5000 PC Desktop
Normal.dotm Won't Adopt Macros & Code is Seen as Full of Bugs
MS's online help section for changing the template is worthless:
http://office.microsoft.com/en-us/word/HA100307561033.aspx
And this MS forum requires a lengthy process to enter anything:
http://tinyurl.com/6pzd3c
This google group for MS word might eventually be use:
http://tinyurl.com/5agok2
Here is my error encounter related to the normal.dot template:
My employer created macros over the years that were working fine in his HP laptop newly installed with Vista and Office 2007.
One day they no longer worked.
Word 2007 refuses to allow me to replace the normal.dotm file with the file that has all the macros.
I have tried to paste the code into the normal.dotm file which works. But when I go to run the macro, bugs are detected and the macro will not run.
  • http://earth-intelligence.net
    Also, excuse me for not realizing until now that this sub-topic was under Presario (which I find abit odd).
  • Will Doak Nov 17, 2008
    I (my wife, actually) has added a macro to a Word document based on my normal.dotx template. When I open a new document, the macro is available. I tried saving such a .docx document as normal.dotm, and Word says it can't do that. The error message says that either two instances of Word are running (not so) or that some other user is editing the document (also not so).
    My goal is to be able to pass this macro along to my coworkers. Can you tell me how to do that?
    Thanks,
    Will
    Scholar:
  • 195 Answers
It sounds like your Anti-Virus or Spyware is blocking and won' t allow access, it thinks its harmful, try turning off the Virus software installed, do your thing and then turn the software back on. If thats not it then your Software is damaged and you will have to install a new copy of Office. Good Luck.
Posted on Oct 28, 2008
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
Normal.dotm conflict in Word 2010. Says file cannot be saved because normal.dotm is open elsewhere. I did try to change the default font but do not know if that is the problem. Deleting or renaming...
This may be a repeat from what you've already tried, but the standard fix for this issue is below.
Click on Start > Run. Type %appdata% and click OK
Go to Microsoft > Templates folder and delete Normal.dotm.
Restart Word
May 03, 2011 | Computers & Internet
Originally my MS Word 2007 stayed open on the HOME tab. Now, the document is not defaulted to any of the tabs (Insert, Page Layout, etc., etc.) until selected. How do I get the Home tab back as the default...
You need to find the normal.dotm file (Microsoft Word default template) and delete it.
When Word starts up again, it will create a new template and that should work.
May 17, 2010 | Microsoft Office Professional 2007 Full...
Word 2007 saves and closes normal.dotm everytime I close it. It doesn't ask for anything, but it shows as an opened document in Word and start menus list.
It could mean that the normal.dot file is corrupt.
Try this:
1. Do a search for normal.dot
2. when found, change the name to "normal.dot.old"
3. restart your machine
Good Luck !!!!!!
Jul 21, 2009 | Microsoft Office Professional 2007 Full...
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
Word template never changes!
tried to delete Normal.dot
you need to search for this file and delte it make sure you enable show hidden files and folders when you search this file
Let me know if it works
don forget to vote me
Apr 19, 2009 | Microsoft Office Word 2007 Full Version...
MS word not responding
Rename all instances of your document template files (Normal.dotm or Normal.dot) This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.
Dec 15, 2008 | Microsoft Office Outlook 2003 for PC
Normal.dotm Issues after MS Update on 7/8/08
Have you tried to run the Microsoft Diagnostics? Open word, select the Office Button, then select word options. Click on Resources and then click on Diagnose.
Jul 14, 2008 | Microsoft Office Professional 2007 Full...
Issue With File Titled "Normal.dotm" in Word 2007
sgoss53080,
Please note that you should NEVER give someone your software's Product Key! Balaji123's inquiry has been reported to the Webmaster.
The issue that you've encountered has no easy solution. Please read this Microsoft Knowledge Base article:
http://support.microsoft.com/kb/924460/en-us
Feb 07, 2008 | Microsoft Office Professional 2007 Full...
Compaq Presario 5000 PC Desktop Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
