Question about Refrigerators
Temp too warm on both sides of my refrigerator
I have a frigidaire side by side and it want get cold or make ice.There is frost on the back of the freezer part
  • 59 Answers
You have a defrost problem. There are three things that are involved with the defrost cycle. There is the defrost timer, which depending on your model is either mechanical (easy to test) or is an electrical board. These are usually placed in near the controls. Second is the heater. The last is the Defrost BiMetal. This is the most common thing to go. The Heater and BiMetal are located on the evaporator behind a panel in the freezer section. With a complete model number I can give you more detailed instructions on how to check each part.
Posted on Nov 02, 2008
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Frost on back panel and not making ice also does not seem very cold.
there is a problem with your automatic defrost system it could be one of three components
Nov 28, 2013 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator is not cooling either the freezer or the fridge I dont know what to do it stays hot.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Place a probe on each terminal. The multitester should display a reading of zero ohms. If the overload protector does not pass this test, it should be replaced.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Feb 09, 2010 | Frigidaire FRS23H7CS Side by Side...
Feezer does not make ice. there is cold water. Installed new filter
Check the temp inside the freezer with a thermometer. It should be between -10 and 0 degrees. The ice maker has a thermostat that cuts it off once the temp gets above 5 to 8 degrees. (According to the model) If your freezer is warm, check the inside back panel of the freezer. If it has ice or frost on it you have a defrost problem. This will have to be repaired before the ice maker will work. If you have ice or frost, your freezer will also continue to warm up until your fresh food section gets real warm.
Please rate solution
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
