Question about RCA P52937 52" Rear Projection Television
RCA GEMSTAR GUIDE PLUS GOLD VERY DIM SCREEN
I BOUGHT THIS USED FROM MY FRIEND. I SHOULD HAVE CHECKED IT BEFORE I BOUGHT IT. THE TV TURNS ON BUT THE SCREEN IS VERY HARD TO SEE,IT IS VERY DIM. I ALSO HAVE NO CLUE ON HOW TO PROGRAM THE REMOTE. I CHANGED THE BATTERIES BUT IT DIDN'T WORK. CAN YOU HELP A BROTHER OUT.
  • 92 Answers
SOURCE: rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Posted on Oct 31, 2007
SOURCE: TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Posted on Dec 11, 2007
SOURCE: programming instructions
HERE ARE THE CODES FOR Philips TV. 1005, 1008, 1014, 1039, 1064, 1079, 1082, 1086, 1099,1104, 1106, 1115, 1116, 1123, 1149, 1150, 1153,1154, 1157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 13511157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 1351
Posted on Mar 31, 2009
  • 84 Answers
SOURCE: I have a RCA Guide plus gemstar remote and can not
i had that same problem. i searched Google and found that on most remotes you need to put a 0 in front because it needs an extra #
Posted on Jun 24, 2009
c17hydro
  • 2984 Answers
SOURCE: i have a rca guide
Okay, when you purchased the remote, it should have had a list of TV brands listed. What you do is find the brand of television that you, which you have listed as a Daewoo, look at the description listed on that paper. It may have a few codes. Follow the instructions for the NEW remote. It will tell you to press a certain button, watch it flash 2 times and then enter the Daewoo code. It should program after that. If you have the OLD remote, you can "learn" the buttons from it to your new one by pointing the remotes towards each other. You will have to press "VCR" and then press, FFWD, REW, PLAY, PAU, etc., pointing the remotes at each other each time you press the button on the old. Sounds confusing but you will see it is very easy.
Post back if it does not work.
Posted on Nov 01, 2009
My freesat remote just stopped working. Ive put new battries in, turned box off and on, disconnected and reconnected it but the remote just wont work anymore please help me
Have you got a video camera? Here is the trick to find out if the remote doesn't really work, or it's the TV that is not picking up the remote signal. Most remote use an infrared led to beam signals to the TV's. And this trick will show you whether that remote's LED is actually working. You and a friend or member of the family is all you need to begin testing your remote. Ask your friend or family member to hold the remote and you hold the camera on without recording. Point the remote about 5-6 feet from the camera. You watch the camera monitor screen while your friend or family member presses the On button or presses the buttons that you think are not operating the TV. With a dim room light, you should be able to see a flickering light coming from the remote in the camera screen. If it's hard to see, which I doubt, since remote infrared LED are pretty bright, you can turn your room lights off and try again. If the flickering LED from the remote is seen and is bright, then try all the buttons on the remote, or at least try the ones that you say are not working with the TV. If all is well, then there is nothing whatsoever wrong with the remote, but chances are that though the remote may beam out infrared light, it doesn't mean it is the right frequency for the TV. It could have lost the frequency and no longer sends the correct signals for the TV. However, the problem can also be with the TV remote's LED receiver. This falls into the hands of a technician's inspection on whether the receiving end of the remote is effective or needs replacement. In this part, you need to have the TV checked.
Nov 17, 2014 | Televison & Video
Rca truflat guide plus gold gemstar tv problems with built in dvd player
Check and replace the optical pickup unit of this set. It is faulty.
Aug 19, 2012 | RCA TruFlat 27F520T 27" TV
Why does my rca guide plus gold gemstar tv have lines or bars flickering on the screen ?
are they horizontal or diagonal? if they are diagonal it could be you're brightness is turned up too high. try turning it down.
Aug 13, 2012 | RCA F36705 36" TV
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
32" RCA Entertainment Series, Guide
Probably not. RCA parts for this model are very difficult to find. Even you could find a kit, it will not have enough to repair. A do it yourselfer or TV tech will have a difficult time repairing this. Please shop for a new TV. Thanks for asking and show a few hands of support!
Mar 21, 2011 | RCA Televison & Video
Picked up tv from friend and cant get it to work
yes. you need to reset guide plus+. with factory tv remote, press.... menu, 7, 1, go-back, tv........ then press menu, 7, 1 , go-back, who-input....... then it will ask you to set up tv with your zip-code.
Nov 09, 2009 | RCA Televison & Video
RCA P52937 52" Rear Projection Television Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
