I have connected a WLAN adapter to my Toshiba RL85 series television
If I then go onto iplayer I don't get a connection and on you tube it informs me DNS not set. Could anyone inform me what I need to do.
nliwilson
  • 114 Answers
SOURCE: wireless won't connect.
First and foremost check that you have WiFi switched on, it sounds so simple but you'd be surprised how often this is the problem. The WiFi switch is on the left-hand side as you look at the screen and needs to be in the up position to be on. A quick note about WiFi security; WEP is useless, even 128bit, freely available 'stumbling' software can crack a WEP encrypted network in as little as 20 seconds (depending on network activity). You need to use WPA or if you're OS supports it WPA2. Hiding you're SSID makes no difference as you're router still transmits and is therefor still visible, it just doesn't respond to access point requests. MAC address filtering is useless because once your network has been found all MAC addresses are visible. These days 'stumbling' software even automates the task of masking one MAC address over another. Although using as many layers of security as possible can help to keep nosy neighbours out WPA (and preferably WPA2) really is the only thing that will slow losers with nothing better to do down long enough for them to get bored.
Posted on Aug 11, 2007
informatica
  • 1114 Answers
SOURCE: Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 16, 2007
SOURCE: Problem connecting Ipod touch to WiFi
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
  • 13 Answers
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Posted on Feb 06, 2009
thesignofone
  • 5 Answers
SOURCE: xbox live via cricket wireless
I can connect to XBox Live through this fashion on my Cricket Modem:
Now, I have had problems with this fix running Windows 7 (still can't get it to work), but I didn't have any struggles with XP or Vista.
You need to go into Manage Network Connections, right click on your Cricket Modem, and select Properties.
Click the Share Tab, and click it so it allows other users to connect through that network connection. Now, go to the Networking tab under Properties and right click on the Internet Protocol Version 6 and make sure it is automatically assigning both DNS and the 6 IP, Apply.
Next do the same with the TCP/IPV4 section under Networking, make sure everthing is automaticaly assigning.
Click on the Router and make sure that it is automatically assigning the Internet Protocol 4 and 6. Now click diagnos, and it should reset the router, automatically apply the correct settings, and bam. You SHOULD be able to connect with XBox Live.
I have no problems with this with Vista and XP, as I stated before. But now my main computer is running the 7 RC and I can't figure the darn thing out yet. So I figured out a cute solution. I took my Dell Mini, connected the Cricket Modem to it, and ran an ethernet cord from the XBox to the Mini.
Pretty much same solution after that, only instead of selecting your router, you select the LAN connection that is not your Cricket. For me itassigns the XBox as LAN and the Cricket as LAN2.
Let's see how it goes. :)
Posted on Sep 11, 2009
How do i use the bbc i player app installed on the tv
There are several different versions of BBC iPlayer which manufacturers use in their devices. Between these versions, due to technical limitations, there can be some variations in features (subtitles, HD etc.). Each device will need to be connected to the internet to use BBC iPlayer.
Without knowing the make and model this is the info available.
Dec 23, 2016 | Televison & Video
Nokia5530 expressmusic WLAN problem
*#62209526# - Shows MAC address of the WLAN adapter.This will be useful while connecting to internet through your phone's Wifi connection.
Jun 20, 2012 | Nokia 5530 XpressMusic Smartphone
Wlan wont connect
no no don't flash the bios , the wlan problem is related to wlan driver go to my computer and then right click , manage then device manager if network adapter has a yellow question mark you will have to reinstall the driver if no you will have to connect manually .
control panel, internet options connectionc , lan settings , click on the automatically detect settings close everythng
Mar 12, 2012 | Acer Aspire 5315 Notebook
40rl858b wont update the software so no bbc iplayer
sorry this is not a solution,just spoke to toshiba and they said to keep trying updates,takes upto ten goes they said,i'm having same problem.done it about twenty times now and still no BBC iplayer
Nov 19, 2011 | Televison & Video
I have a gold star hd30 dehumidifier. When it was draining into the bucket it was running properly. Recently I installed a hose at the back by inserting the plastic piece provided onto a black tube inside...
Quite possibly, Sara the hose drain tubing was not seated firmly. or the tubing running to the hose connection is partially clogged . When this happens water is diverted to the bucket.
To solve the clogging issue do the following:
Turn the unit OFF & Unplug it.
Remove the the tubing adapter and using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the the tubing adapter and tubing, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the drain tubing for water flow and leakage. It may take 10 minutes to start flowing, so be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you to solve the problem and thanks for choosing FixYa.
Sep 13, 2011 | Goldstar DH3010B Dehumidifier
I have a level one wap 0004 wireless access point. I also have a panasonic blue ray player that i am trying to connect the adapter too. The blue ray player has an ethernet connection. The 2 are now...
so, depending upon if you are connecting it with a cable or wireless it is a little different. Wireless sometimes has wps button too for a quicker config/connection.
I suggest you Check the manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiUnI_205zTAhUE7YMKHfM-Cv4QFggaMAA&url=http%3A%2F%2Fdownload.level1.com%2Flevel1%2Fmanual%2FWAP-0004(EN).pdf&usg=AFQjCNGJRGXedGyKrPDAD2yOSP0CIN39wA&sig2=Rq3EoRlhyzd_LmCLkg8VwQ
Often you go to the url of the routers IP address but you need to know that and the default username and password for administrator, which BTW you may wish to change so only you know it.
Apr 11, 2017 | Levelone WAP-0004
I can't connect wlan security incorrect.
Sorry to said but you have to use the correct WLan password. If you don't know this password you have to connect at the router's settings page using an ethernet connection, locate the Wi-Fi (or Wlan) section and at the security section find the requested password.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. Also clarify me the brand/model for your router.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Computers & Internet
Hi there, I have a samsung gt - s5620 monte, when I go onto BBC I player on the Internet browser the page comes up but the pictures and videos won't appear or play. It has worked before and this is a...
Hi there, I'm afraid i don't have a solution, but your not alone, my iplayer doesnt work either.... if i can get it running i;ll let you know! m
Jul 29, 2011 | Samsung S5620 Cell Phone
I just bought a toshiba tv model 40ux600u and the wlan wireless adapter. I am trying to connect to my pc and its not working. It shows my wireless connection available but when I type the security code its...
You are trying to connect the TV to your PC? I'm sure the TV wasn't designed to allow that, unless you have set the PC to act as a "access point" such as a wifi router, i'm afraid you are trying to connect the wrong bits of kit. now if you connec the TV to the same router your PC is connected to, you can share files via the network.
Jun 18, 2011 | Toshiba Computers & Internet
My m105 works great but will not hold a wireless connection. Please advise....Allan...
Hello
Disable firewall settings to check if it doesn't block connection.
1) Update the WLan driver. In most cases this solves connections issues.
http://aps2.toshiba-tro.de/wlan/
2) Go to device manger -> WLan card -> Properties -> Advanced tab and check if the WLan modus 802.11 B/G or N has been set to the same Wlan modules supported by router!
3) Disable the WLan encryption and password on the router and check if you could connect to the router without any security settings. Do this only for testing purposes. If it connects properly, enable the encryption password and try again.
4) Disable WLan power saving! This can be done in Win Power Management. If that doesn't work, perform a system restore, set your computer to how it was the last time you were on the internet.
Apr 15, 2011 | Toshiba Satellite A105 Notebook
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
