Question about Toshiba Satellite A75-S206 Notebook
How do i reAIR THE POWER BUTTON A75-206
The power button went inside the pc
    Scholar:
  • 67 Answers
This isn't the exact same model, but it should be helpful.....
http://www.youtube.com/watch?v=pbF0lOLi7Cg
Good luck
Posted on Feb 22, 2012
3 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite A75-S209 (PSA70U-09700E) PC
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Posted on Nov 13, 2009
IB4G2008
  • 3587 Answers
SOURCE: Laptop simply stops on starting
take out the battery, plug in ac only, and try it again
Posted on Mar 23, 2008
I have a brada dishwasher the power button won't turn on
My brass power button broken
then I put knife into the button.it will start
after month power button went inside
know I can't start the button
what can I do
Apr 24, 2016 | Dishwashers
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
Well we had a power outage today and when the power came back the computer went back on but instead of starting up windows the blue power button flashes. but the fans and components inside the computer...
if there is no post sound (beeps) and the pc does have a speaker you can try this first.
remove the power cable
hold the power button in for 15 seconds to clear the residual power.
replace cord and power on
if you still have the same result, then you need to learn how to reset the bios/cmos on your system.
Jun 27, 2011 | Computers & Internet
My monitor started to give me problems when I first turn it on I have to push the power button several times before it will stay on it's the samsung syncmaster 203b
you need your power supply reaired. the capacitors go bad. remove the covers and look at the power supply reeplace any leaking and or crowned capacitors
Jan 01, 2010 | Samsung SyncMaster 203B LCD Monitor
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Big screen tv will not turn on
Problems are in power supply or scanning circuits. Unit is in need of reair. Call in pro/tech
Nov 30, 2007 | Akai PT4298HD Rear Projection Television
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Panasonic model TX-29GF10X, went on stand by , and not Switching ON again, what is the majore cause?? or what does the TV need to restart again
Your problem im afraid could be one of several things. Power supply problems,sweep supply,horizontal output transistor,standby power supply. The best thing for you to do , if your not a tech, take the set into a reair depot as these are solid state sets and have no user replaceable parts inside. Good Luck
Aug 28, 2006 | Sony KV-32S26 32" TV
Toshiba Satellite A75-S206 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
