Question about Marvel (6CAR) Refrigerator
Frost forms immediately in wine refrigerator 6BARMARWRP
This wine refrigerator was purchased by a previous owner in 1997. I cools nicely but frost forms quickly. It needs to be defrosted every 2 to 3 weeks even if door has not been opened. Is it suppose to be frost-free? Is there a part that needs to be replaced?
    Scholar:
  • 112 Answers
I would check the unit for air leakage. A bad door gasket seal will do it.
Posted on Oct 27, 2008
I have frost on back of unit.what to do?
Usually if you see frost or ice it is because the Freon level is low. There is a 5 year warranty on the compressor and sealed cooling system so if your within that period, I would call the manufacturer.
May 14, 2016 | U-Line 75WC Wine Cooler
My refrigerator is cool but not cold. My freezer is keeping things frozen but takes longer to form ice (no ice maker) and my ice cream is soft. I hear the motor running and I do not have any frost build...
Hi Nancy,
I bet you've got all kinds of frost / ice behind the plastic cover that protects (and shields from view) the cooling coil in the freezer compartment.
You probably have one or more: defrost timer, defrost terminator or defrost heating element that has failed. Call for service - or empty the fridge and unplug with door open for a day - ice will melt and when you plug in again it will work just fine. Until frost builds up again that is.
May 12, 2015 | Frost Refrigerators
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Jan 09, 2014 | Whirlpool Refrigerators
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I have a GE ZDB24A under counter wine cooler that continues to frost up regardless of the setting. I have a second cooler downstairs which stays clean - no frost. What do I need to do?
check the door seal, make sure that its not ripped or dirty. Its possible that moisture is entering the wine cooler thru the door gasket. Frost is normally the result of warm moisture mixing with cold air. The door gasket should be the problem. if you thoroughly examine and its fine, let me know and we'll go to the next step.
Feb 06, 2011 | GE ZDB24A Wine Cooler
Items in freezer on top level have frost on them. It is appearing on top right side (as you face freezer). Long, "furry" frost has formed.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
Last month I had a problem with my Kenmore side-by-side #596-52673200. My refrigerator would not get cold. I followed the suggestions of one of your experts and remove the ice and frost behind the panel in...
HELLO,
The non cooling is brought by the Expanded and Rapidly cooling air which keeps it cool is being blocked by the ice, and simultaneously being condensed by the temperature difference... The ice blocks its path and forms frost...but there is obviously air coming in contact with it...The problem is typically air is leaking in the fridge somewhere, make sure doors shut tight after cleaning the frost in the back panel...this should do it...:)
Sep 08, 2009 | Refrigerators
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
My Frigidaire freestanding wine cooler only seems to cool as low as 53 degrees when I have it set to its minimum temp. The manual says the minimum temp should be 40. Is something wrong with the unit?
YES! Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush
Aug 22, 2009 | Refrigerators
I have an 8 year old side by side refrigerator that is not cooling right. We turned the temp to make it colder and its still not cold like it should be. Also, I'm noticing condensation in my drawers and...
Turn your refrigerator off and remove the back wall inside your freezer section. Use a hair dryer to melt off all the frost and ice. The frost was blocking the flow of air over those cooling coils, resulting in very little cooling. The most likely cause of this condition is burnt out defrost heater(s). It can also be caused by a bad defrost thermostat, air leakage like a door left open a long time or bad gaskets, or a bad defrost control.
Aug 16, 2009 | Refrigerators
Marvel (6CAR) Refrigerator Logo
298 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
