Question about Ovens
Ceramic hob has a crack in it on Beko DVC 665. Is it dangerous? Can I get it fixed?
Top oven not working of my BEKO DVC 665.
Posted on Jan 04, 2015
4 Suggested Answers
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
Posted on Aug 30, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
  • 3 Answers
SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
Posted on Sep 17, 2010
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
May 16, 2010 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Loose beko oven door ??
CHECK FOR A SLOT WHERE THE HINGE GOES INTO IT MABE YOU CANT SEE IT BECAUSE IT MIGHT BE CLOGED WITH FAT CLEAN WITH SOAPY WATER AND FIT THE PIN INTO THE SLOT AND IT SHOULD BE FIXED,
Nov 29, 2009 | Ovens
Beko oven door - permanently detached?!
Hi - in the end I found the cheapest local oven repairers and they ended up having to do a bodge job ... they admitted that Beko was a bad brand with lots of design problems, this being just one of them. By disconnecting and opening up the back he managed to get one of the hinges back on (with my help!), but for the other he had to resort to using bigger screws coming in from the front. Recently, after less than 18 months of use, the oven and one of the hotplates stopped working on the same night. I gave the whole thing up as a bad bet and ordered a more expensive Indesit I'm now completely happy with. I think with ovens you get what you pay for. I would never touch another Beko ANYTHING with a barge pole!
Jul 28, 2009 | Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
English Instruction Books required
Hi there ..it is possible these products are for the Turkisk home market and therefore no need for English Instruction....however i am checking this out for you and will contact you shortly
regards Sir Galahad
Dec 13, 2008 | DCS Large Appliances Built-In Ovens...
Ovens Logo
122 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
