Question about Hitachi HDS721025CLA382) 250 GB SATA II Hard Drive
Download the driver for Hitachi HDS721025CLA382) 250 GB SATA II Hard Drive
CompuGuy44
  • 432 Answers
SOURCE: HITACHI DESKSTAR 7250 320 GB HARD DRIVE
File on disk maybe bad. Try this website: http://www.mes.cbs.dk/~sttt/readme.txt and http://www.geocities.com/SiliconValley/Network/2963/files.html
Posted on Jun 23, 2007
SOURCE: Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
Posted on Jan 23, 2008
Maanita
  • 1142 Answers
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
Posted on May 04, 2008
joecoolvette
  • 5660 Answers
SOURCE: I am attemping data recover on Hitachi 80 GB 2.5" SATA hard drive, need instruction to open cover, etc.
Generally there is a small screw, (Or two of them), that go through a thin metal tab, affixed to the harddrive. They usually have a strip of thin cloth, that you pull on, to ease the harddrive out, after the screw is removed. Sometimes it's hard to see.
I have to give you this information in a generic form, because laptops differ in the way they keep the harddrive in. I better go ahead, and tell you, that this specific info may not be available, for your particular laptop. However, you may want to come back, and post the laptop manufacturer name, and model number, in case it is. (I've worked on many, and have a lot of information available, but am being straight up front with you, that I do not have info available for every laptop out there. Just trying to help, is all)
Posted on May 22, 2009
SOURCE: my hitachi hts541680j9sa00 80gb hard drive is trying to boot up windows Vista but I get a blue screen 0x0000007b,0x81e03ba0,0xc0000034. I have tried vista disk system repair and it shows not OS and a
i hav hitachi hdd it has pass word and i have forget them is there any universal pass word i need them
Posted on Dec 17, 2009
Won' recognized my external hitachi z5k320
check data cable.
change use port and check the driver on any other PC.
if problem is same after doing so. check hard drive Cage. change driver Cage
Jul 14, 2014 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Driver win xp
If your indicating windows cannot find your hard drive during set up, you will need to know the name of the SATA RAID device on your mobo, download the drivers on to a floppy and install them during windows setup at the "press F6 for 3rd party raid drivers" prompt.
May 12, 2013 | Hitachi HTS542512K9SA00 120 GB SATA Hard...
Hitachi H3D10003272S, 3GB/S or 6GB/S ?
That hard drive has a Sata II (3b/s) interface so you won't get any extra performance from a Sata III (6b/s) port, but it will still run, but it will run as Sata II (3b/s).
Any it should be 3gb not 3gB
b = bit
B = byte
byte = 8 bits
So you would think that a 3gb/s would operate at 375MB/s but manufacturers advertise everything as 10bits = 1 byte so you have to take the speed or even hard drive size and multiple by .8 to get the actual speed 375 * .8 = 300MB actual speed.
Jul 19, 2012 | Computers & Internet
Drive address setting with Hitachi (39T2703) 60 GB SATA Hard Drive
i'd go to the hitachi website and download the driver to your pc,then install/update,look on ystem administrator specs for info about hard drive,simple
Jun 10, 2012 | Hitachi (39T2703) 60 GB SATA Hard Drive
Hello, i need a driver for a Hitachi HTS545050B9A300 hard drive. thankyou.
Hello , You do not really need a driver to install a new hard disk in your computer, You have to activate the port you connected the driver in the bios of the computer Once the bios detect that new drive, it will be detected by Windows
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 17, 2011 | Hitachi Travelstar 5K500.B HTS545050B9A300...
My laptop keeps blue screening point to hard drive issues
have your hard drive tested for errors you may use HD-tune for your own testing, if it pass the test, you may need to replace your laptop hard drive interface assembly or check your ddr memory for defects also..
Feb 09, 2011 | Hitachi Travelstar 5K500.B HTS545050B9A300...
This is a jumperles HD How to switch ftrom SATA
Http://hgst.com and download the hitachi tools for this drive. It is set via software.
TechRx, Inc. - Green Bay
Apr 19, 2010 | Hitachi DeskstarĀ® T7K500 320 GB Hard Drive
Upgrade hard disk :SATA compatible with SATA2 ?
Dear,
Yes, You can install a SATA-II hard disk in it. There is no problem.
Regards,
Rakesh Kumar
Apr 06, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Need a driver
Your hard drive doesn't need a driver ... the sata controller on the motherboard that the hard drive is connected to does.
You will probably find the driver on the cd that came with the motherboard in a folder called "RAID" or "SATA" or "device drivers".
If you don't have the CD you will need to visit the website of the PC/Motherboard manufacturer to download it.
Apr 18, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Hitachi HDS721025CLA382) 250 GB SATA II Hard Drive Logo
308 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
