Question about Black & Decker Mouse Sander/Polisher
Ka150k dead Is there anywhere that repairs the palm sander KA150k.
  • 2,176 Answers
If this is a Black and Decker like the header states you can go to dewaltservicenet.com and they have a service center locator that you can find a repair center close to you. If another brand give me the brand and your location and I will try and find someting for you.
Posted on Mar 12, 2012
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Do you get brushes for the motor of a KA150K mouse
I would go to Dewaltservicenet.com and download a breakdown for this tool and also you can find a local dealer in their locator section.
Posted on Jul 22, 2010
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
Frozen barring at the shaft / pad union, is it worth repairing
yes it is usually bearings cost less than 10.00, you can download a breakdown from Dewaltservicenet.com to see what is involved.
Nov 28, 2010 | Porter Cable Cable 340K 14'' Sheet Palm...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Do you get brushes for the motor of a KA150K mouse sander? Are they easy to fit? Could you supply an exploded diagram of the unit? Thanks
Jun 08, 2010 | Black & Decker Mouse Sander/Polisher
Broken belt on Porter Cable 334 T2 palm sander
got it, go to Dewaltservicenet.com and download the instruction manual or look at it and on page 14 it gives a really great view of how to replace the belt. If I have helped you with your question would you please rate this response accordingly and thank you
Oct 12, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
I can't find parts for a Craftsman 5" Orbital Palm Sander
a band aid fix, if the hook and loop is wore out, but the pad is ok, is to get a peel and stick hook and loop pad that you can stick on the pad
Jul 22, 2009 | Tools & Hardware - Others
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Black & Decker Mouse Sander/Polisher  Logo
265 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
