Question about Frigidaire ATF6000ES Front Load Washer
The machine will not start only blinks pause an the door lock does not lock
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
My AEG Lavamat 52810 has become faulty. The machine pauses about ten times during the cycle and the lamp marked "door" blinks. When I press the start button, it stops blinking and the cycle...
Hi Richard from retired Englishman in SW France,
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and
/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 14, 2011 | Washing Machines
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH5500BWW will not spin out. Unplugged to reset and all lights will blink and set to pause. When you press start, it eventually clicks like it is locking to start, machine turns off and...
it sounds like a door latch problem. the door latch has a small "wax" motor in it that causes a lot of problems. unless you have a bunch of time to spend learning about how it works i would suggest calling a professional.
Jun 29, 2008 | Maytag Washing Machines
Front load Washer
You have to clean-out your inlet hoses; the hose/s external of machine, the screens. You may not be getting sufficient water.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
May 03, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
