Question about Philips 32PW6506 32" TV
Horizontal lines Hi there, Hoping for some tips on a faulty TV set. We have a Philips 32PW6506 32" TV which is experiencing intermitent horizontal lines. The lines are tighly squeezed, distort the picture and move up and down the screen. Also strangley, the number of lines or the intensity seems to change with the changing picture ie if a scene changes completley, then the lines will swithch off or change. Anyone any ideas? Thanks in advance, Conor
Http://home.tiscali.nl/m.majoor/tv__matchline_service_mode.htm Sounds like you need go this site, enter codes and re callibrate your TV to the settings. If this does not work - then sounds like you need tv repair man replace caps or solder bad joint. Miyan sung, former philips rep man, Korea.
Posted on Oct 03, 2007
SOURCE:
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My (2) Philips Magnavox 27TS54 C101 have lost the picture accept for one white horizontal line.
Hi Dean,
White horizontal line then the unit automatically shuts off with a led blinking on the front panel is an indication of faulty vertical deflection circuitry.
The most common faulty parts is the vertical deflection IC (TDA9302H) itself. This IC is mounted on the aluminum heat sink near the flyback transformer. You have to replaced it with new one to resolve the issue. Click HERE to have an idea how much it will cost for the parts.
Hope I helped you.
Good luck and take care!
Jdvillanueva
Jan 11, 2012 | Philips Televison & Video
Hi....i have a horizontal faded green line at the bottom of a 42 inch full hd philips lcd ....the line started showing through hdmi cable(tried to replace the cable but in vain)...now the green line is...
Hi, Lines across TV are caused by leaky condensers. Horizontal lines mean the faulty condenser causing the lines is located in the vertical section of the TV's PCB. You will most likely have to get a technician to repair it unless you are very good with electronics and soldering. Shouldnt be very expensive as the components are dirt cheap, Its just the labour cost that may be pricey. Best of luck.
Apr 14, 2011 | Philips Televison & Video
Horizontal grey lines and tv cuts off by itself after 10 sec
Anyshop would take this under coinsignment as a bad Horizontal IC
"intergrated circuit"
But do not shoot the messenger, its going to need a shop, I would not recommend you opening this unit and risk a fatel shock or Death. Just the flyback transformer alone could kill you. Not to sound harsh but please understand, I do not want fixya to be on the late night news that it gave someone a solution that could have caused injury or death, if your not experienced take it to a shop. You cost if it is a IC witch it sounds like to me your looking $75-$100 parts and labor.
Thanks for your intrest in fixya.com please do rate and leave feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2010 | Philips Magnavox TP3285C 32" TV
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
Lines on tv
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Dec 26, 2008 | Sharp 25L-M100 25" TV
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
Apr 01, 2008 | Philips Magnavox MS2530C 25" TV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Philips 32PW6506 32" TV Logo
284 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
