Question about Sony Video Game Consoles & Games
PS2 Dual screen display
Can i set up a ps2 with dual displays so each player has their own screen. Preferable a system that can be transported easily
  • Dewy71 Oct 28, 2008
    I have a single PS2 but want each player to have their own screen rather than having a single screen that is split when playing multi-player games
    Genius:
  • 1,550 Answers
Can you be clear with your problem .
You can setup ps2 with dual screen .
Posted on Oct 27, 2008
My sony ps2 have black and white output to tv
hey it is due to the model of your ps2 and your game is PAL and your TV is NTSC or the other way then it would give you black and white screen.the model of ps2 is written on its back side if both your tv set and game and ps2 are pal then there might be a problem with your ps2 av cable or ps2 itself
Jan 15, 2013 | Sony PS2 Dual Shock 2 Controller...
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
How to fix ps2 display settings
You can adjust screen display settings while playing PlayStation 2. Press the PS button on the Wireless Controller during gameplay and then select [Settings], adjust the following settings. Screen Mode Normal: Set to upscale and display at a size that matches the screen size. Full Screen: Set to upscale and display at full screen by changing proportions and stretching the image. This setting can be selected only when [Normal] or [Full Screen] is selected under Settings > [Game Settings] > [PS / PS2 Upscaler].
Mar 31, 2011 | Video Game Consoles & Games
Extra Space Filler? PS2 hook up?
try any audio shop . its called an install kit. and as long as your unit has a/v input you can wire the ps2 right to it
Feb 08, 2010 | Dual XDVD8181 Car Video Player
I can't get my PS2 to connect to my dual xdvd270
You can connect the PS2 Video out (composite video out) to any of the 2 monitors video connector and the audio at the audio connector, remember to select A/V ext (External Audio and video) both video and audio uses 3,5mm jacks, if it does not work you might need to try to draw out the jacks a little, the connectors are of poor quality so be carefull.
You also might want to check if the right system is selected PAL/NTSC, check the format from your PS2 and set the monitor to accept the same signal type, then it should work fine.
The only thing I am not sure how you do is to get the composite video out of the PS2 but study the manual or google and you will find it I guess, but my guess is that you allready have that part covered.
Jan 03, 2010 | Dual XDVD270 Car DVD Player
Ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Jul 26, 2009 | Sony PS2 Dual Shock 2 Controller...
William's steering wheel not working
My steering wheel is a intec G7796. It will not work with my foot pedals on nascar 09 Is it the game or settings.
Jul 05, 2009 | Video Game Consoles & Games
Dual shock does not work or led display on controller
If it is wireless put your ps2 infront of remote
Buy a new ps2 or remote
Feb 28, 2009 | Sony PlayStation 2 (PS2) Console
PS2 doesn't play color
is u r ps2 modify if yes than try this
turn off u r ps2 and press 2 buttons togather trangle and cercle now turn it on u get one menu in u r screen and in first line of menu u get ntsc wrriten press X buttons u get it change turn it in pal o r ntsc
now press start button in u r joy stick it will display setting saved now turn off ps2 and turn it on now u get colours in u r games . REMEMBER U R PS2 SHOULD BE MODIFY SO U CAN DO ABOVE SETTINGS
WITH MODBO 3.0 IC IT WILL DISPLAY MATRIX WHEN U GET IT START U R PS2
Jan 16, 2009 | Sony PS2 Dual Shock 2 Controller...
Can u hook ps2 to dual xdvd700
No you can not hook up a ps2 to the dual. It hads audio inputs but no video inputs
Oct 09, 2008 | Jensen VM9510 Car DVD Player
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
