Question about Sharp 25L-M100 25" TV
Cable connections How do i replace my cable connection on the back of the TV? And where do i get one?
    Problem Solver:
  • 5 Answers
Need to know what type of connection is being used If a scart it needs to be removed and replaced with identical fitting
Posted on Oct 27, 2008
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
No visual for Nintendo Wii, replaced cables, audio fine.
Did you hit the input button on your TV remove to select the input where the Wii is connected? If you TV allows for Component cables try getting a set of those. It's a possibility the TV connection has gone bad. Try connecting it on another tv. or some tv's have Audio connections in the front/Side/back.
Oct 12, 2013 | Nintendo Wii Console
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
How do i connect my cable box to my tv
Connect the coaxial "Cable In" cable to the "Cable In" port on the back of your TV cable receiver box. Make sure your receiver box is not plugged in yet. 2 Take the TV audio/visual cable, and connect the red, blue and green ends to the corresponding color "Cable Out" ports on the back of your cable receiver.3 Take the other ends and plug them in to the red, blue and green ports under "V1" on the back of your TV.4 Take the audio cord with the red and white ends, and connect them to the corresponding color ports of "Audio Out" on the back of your cable receiver; then, connect the other ends to the corresponding color "Audio In" ports on the back of your TV.5 Turn on the power of your TV cable receiver box first. Allow it to run through the boot sequence. When you see the time appear on the front of the cable box, you may turn on the television and check your signal.
  • Oct 13, 2011 | Televison & Video
    6 pink lines verticle on 50 inch lg
    this problem is related to lcd panel of tv. u need to unplug the tv remove back cover of tv, have a close look at cables connected to lcd panel. disconnect the cables & connect the cables again. if problem not solved, replace the lcd panel.
    Aug 25, 2011 | Televison & Video
    I have a Sanyo Tv model # SC31520 that dose not have a Cable jack on the back how do I hook it up to the Cable if it does not have a cable jack on the back
    You will have to purchase cable that was once used to connect an older VCR to the TV. This cable connector will go into the RF connection of the TV to the RF connection on the cable box. If the RF connector you are looking for in the back of the TV is gone...you will have to find a TV tech to attach a new RF connection to the tuner of this TV. Hope this will help with a solution!
    Feb 13, 2011 | Sanyo DS31520 31" TV
    I want to connect to a TV that;s already connected to a cable tv box
    What do you mean? Do you want to connect or add another tv to that cable box?
    Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
    If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
    Hope this helps.
    Sep 21, 2010 | Televison & Video
    56 inch tv
    The T Con board at the top of the back panel has 2 flat cables that connect from this board to the main board. Check these connection. Be careful. Lightly sqeeze in on the sides of the connector and pull. Push cables back in. Check picture. an you get any graphic from the tv on the blank side. If you can then definatly Main board is bad. Other wise replace the flat cable (FLDS cable) on side that is missing video. next replace the t conn then next replace the panel. I think the t conn board on this set is part of the LCD panel. It is Likely cheaper to replace the tv if the panel is bad.
    Mar 25, 2010 | Samsung LN55A950 55 in. LCD TV
    Cable connection in rear of TV broke off.
    This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
    May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
    Female coax connector in tv bad?
    If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
    Aug 30, 2007 | Sharp 27J-S100 TV
    Sharp 25L-M100 25" TV Logo
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
