Ok then how would i set up alap top to use bluetooth
  • 32,281 Answers
If your laptop is bluetooth enabled then install the bluetooth driver. When the bluethoot driver is installed and the bluetooth is switched on then the laptop will detect any bluetooth device that is within range and you can select that device to connect with your laptop.
Posted on Feb 23, 2012
I have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
How if my Asus Eee PC 1215P there is no bluetooth but i want have it?
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 27, 2012 | ASUS Eee PC 1215P-MU17-RD Netbook
My samsung BD_C6900 has no connectivity to the internet
if this is alap top make sure the ant. is hooked up push blue fn+hold ago to f1 f 2 orf3 should have picture of ant. holdblue fn+push ant key this should solve your prob.
Jul 01, 2012 | Samsung Bd-c6900 3d Blu-ray/dvd Disc...
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 | Cell Phones
I can't download the pictures off my pantech cell phone
You can connect your Pantech Link to your Windows 7 computer using the phone's built-in Bluetooth adapter. If your computer doesn't have a Bluetooth adapter bulit-in, you can connect the phone via a USB port. Once you connect your Link to your computer, you can use the phone as a modem, or transfer files back and forth between the phone and the computer.
Press the "Menu" key on the Pantech Link and select "Settings."
Open "Connectivity" and choose "Bluetooth," then "Activation." Set the option to "On" and press "Select."
Click "Back" and open "Visibility." Click "Show" and press "Select."
Click "Start" on the PC task bar, then click "Devices and Printers."
Right-click on your Bluetooth adapter and left-click "Bluetooth Settings." Check the box labeled "Allow Bluetooth Devices to Find This Computer" and click the "OK" button.
Click "Add a device" at the top of the screen. A new window pop ups, showing the nearby Bluetooth devices.
Highlight the Pantech Link and click "Next." A random number appears on the next screen.
Wait for the Pantech Link to prompt you for the number, then type the number into the phone and press "Select" to finish the pairing process.
Right-click on the Bluetooth adapter on the computer and left-click "Bluetooth Settings." Uncheck the "Allow Bluetooth Devices to Find This Computer" box and press the "OK" button. This prevents the computer from showing on other Bluetooth devices.
Regards.
Jun 18, 2011 | Cell Phones
"Memory Full but i have 4GB"why?!?need help...
Go to the "Settings and Tools" menu.
go down to "Memory" and press [ok]
Press [ok] on "Save Options"
Arrow down to "Sounds" and press [ok]
Your phone is set to "Phone Memory"
Select "Card Memory" [ok]
Now set the Pictures and Videos the same way!
Hope this helps!
Sep 19, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I have a LG Vu and I want to use the bluetooth setting to download photos into iPhoto. How can I do this? I have tried and tried to no avail, my imac book still shows no connection. Help me please!
What you do is find the bluetooth symbol at the top of your screen (the background) then go to SETTINGS and then to DEVICE VISIBILITY (should be the very top) hit the ON choick then OK for other bluetooth devices to recognise it. then go back to the MAIN BLUETOOTH MENU (just hit back button) and go to SEARCH NEW DEVICE (second one down) but make sure you are in the same room as your computer to have your phone connect with the computer. That should then find your computer and then REQUEST TO PAIR (just touch the name of your mac) and then ENTER THE CODE (should be four zeros if you didnt change it and do the same thing on your mac then after that just select the photo you want to send and hit SEND VIA BLUETOOTH and select your mac
Jun 29, 2009 | LG KU990 Viewty
Detect & Connect Motorola HS801
HS801: Enter pairing mode by simultaneously holding down volume and Connect/disconnect key (Chrome finish key next to blinking BLUE LED.) When BLUE LED is steady, headset is in pairing mode. LG TU550: Menu key (top left button) Select SETTINGS; '5' CONNECTIVITY; '1' BLUETOOTH; '1' BLUETOOTH on/Off; '1' ON; '2' DEVICE LIST; Select NEW (Top Left hand Button) LG searches for new device/s; . Select HS801; Press OK; enter password 0000. Connection is made when HS801 BLUE LED resumes blinking.
Apr 27, 2008 | Cell Phones
Bluetooth GPS Tom Tom to operate with PDA Xda IIi
Have you tried using 'other wired device', try each com, rather than bluetooth, on tomtom configuration settings, works for me with TT5 and a Holux BT GPS reciever
Jan 28, 2007 | O2 Xda III
Open Questions:
Getting Smart With: Toshiba Printer Contact Number 1888784-9316 For USA V If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Care, which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
May 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
