Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
How to replace fuel lines on Poulan P3314 - Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
  • 885 Answers
I am asuming you are already into the saw and looking at the carb and tank. There are two fuel lines, one gets gas to the carb, the other returns gas to the tank. The 'in' fuel line has to be long enough so you can pull it out the gas fill hole to attach the filter and to rest on the bottom of the tank. (The weight of the filter will keep it on the bottom.) The 'out' line only has to be long enough to go into the tank but not vibrate out. Both should be fairly snug in their holes so gas won't leak out around them. Either line can go through either hole in the tank however, one hole is usually easier for each line to run in without kinking. If you don't know which nipple is which on the carb, put one end of a line on one nipple and the other end in some gas and pump the primer. If it sucks gas up, it's the 'in' nipple, if not it's the 'out' nipple. If you got the 'out' nipple, be sure to check the other to make sure the primer is working properly.
Posted on Feb 23, 2012
mash_jumbie
  • 138 Answers
SOURCE: I need a manual for my Poulan gas chain saw. It
this is the link to get your manual.
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/p3314_p3314ws_p3314wsa_p3416_p3516pr_p4018wm_p4018wt_p3818av_p4018av_1.html
Posted on Mar 05, 2010
SRF518
  • 232 Answers
SOURCE: My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Posted on Oct 24, 2009
  • 10865 Answers
SOURCE: saw does not idle
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Posted on Jun 24, 2009
Editor925
  • 285 Answers
SOURCE: I just purchased a new model P3314 Poulan chain
PDF manual for the P3314 Chainsaw can be downloaded here
Posted on Mar 09, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Posted on Sep 04, 2009
HOW TO ADJUST THE CARB. ON A MODEL P3314 WILL START AND RUN FOR ABOUT 15 SECONDS AND THEN STOP RUNNING.
suspect that the diaphragm is going hard and is not sucking the fuel up from the tank properly
rekit the carby
Oct 02, 2016 | Poulan Garden
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Fuel line is broken 2 inches short from filter in tank. How do u replace line? Do you need rubber grommets etc.
if you go to home depot you can buy a fuel line kit for a few bucks that comes with all of what you need
Mar 01, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Started reving very fast wont idle ;was the correct fuel mix was cutting on side ie not down
Check your all of fuel lines for cracks / air leaks especially near any fittings. Also check the primer bulb (if installed) for any pin holes. The symptom you describe is either caused by fuel starvation or the introduction of air into the fuel system. Also check inside the gas tank looking at the fuel pick up tube END / strainer for debris. Make sure that the gas cap remains vented. If some one has placed plastic over the fuel tank fill hole and then the gas cap it will perform as you stated. This model also has a mini fuel filter that can be clogged causing fuel starvation.
See this link:
http://www.ereplacementparts.com/poulan-p3314-type-gas-chainsaw-parts-c-16962_17147_17782.html
In DETAIL A
There is a fuel line item A7 and a tank purge device item A6 that is often where the air leak presents itself.
in DETAIL B
The primer bulb item B14 and the purge line B13 are also a major source of air introduction.
Once you get the feul system sealed again by repair of the fuel lines or replacement of the primer bulb you should be back in the wood cutting business again WITHOUT making carb aadjustments.
Thanks for choosing FixYa,
Kelly
Jan 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Jan 28, 2010 | Poulan Garden
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do you get new fuel line into the gas tank of poulan chain saw?
FIrst off be sure you have the correct size line. Poulan uses several sizes of fuel line. If you got the wrong one, you won't get it to go in. The best way is to cut the tip of the fuel line at an angle. If you warm the fuel line before inserting it, it will go in easier. Once you get it forced in a little ways, you can reach in with a pair of needle nose pliers and pull on the fuel line while pushing it in from the outside. If you bought the line from a Poulan dealer, then instructions would be included along with the end being precut at a long angle to assist with installation.
Feb 22, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
2,936 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
