Question about Garmin aera 500 Color Aviation GPS
Garmin aera 500 sat problem
Problems acquiring satellites Seems like antena is not working
  • 4 Answers
SOURCE: having problems acquiring satellites
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Posted on Oct 03, 2007
SOURCE: garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Posted on Jan 31, 2008
  • 40 Answers
SOURCE: won't acquire satellite
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 02, 2009
  • 171 Answers
SOURCE: battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
Posted on May 09, 2009
SOURCE: Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Posted on Dec 30, 2009
Garmin 1300 acquiring satellites problem
Hello
I have a nuvi 1250 and what i did is i put it on my windshield just below my review miror. [and i am telling you this ]it cut the serching in half. and i think that the radio antena might help but i was told that they do that alot so that they are on top of any problems.
good luck,
Jun 27, 2012 | Garmin nuvi 1300 Car GPS Receiver
My gps172c fails to receive any sats...same problem last year,boat laid up over winter and in spring when set switched on no sats picked up .Garmin sent me software update and problem solved. Unfortunately...
Similar problem with a Garmin finding current position taking very long time every spring after boat being laid up in winter.
See page 4 and 5 to speed up the process.
When Garmin does a power-up the current version is revealed during the boot. This will ID the update!
The at home(current position) delay maybe due to satellite re-position during the winter and has been the only problem. Once acquired have little or no problem rest of season.
See page 6 on link manual where you can observe the satellite acquisition. During the initial acquisition process it seems to start over many times and eventually locks them in one at a time!
http://static.garmin.com/pumac/GPSMAP172C_OwnersManual.pdf
Hope this helps?
Jul 04, 2017 | GPS
Updates for garmin sat nav
To increase the accuracy of your Garmin Nuvi 205W, I recommend you use Garmin's WebUpdater service to make sure you have the latest software on your device. Software improvements for acquiring satellite lock and location accuracy have been made.
I hope that helps.
Oct 05, 2009 | Garmin nuvi 205W GPS Receiver
Will not aquire satelite signal
go to a location where ther eis clear view and no obstruction from a clear sky, or else reset the gps again
Jul 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Hi.I have Garmin 755 and need to help me.When i bought it ,it's worked good .It has 8 month old. The problem is,when i turn on ,working fine 1 minute, after that i saw on it that: Acquiring...
I'm not sure if you are aware but there have been recent warnings that sat navs may start to fail and will stop working all together by 2010.
May 22, 2009...3:34 pm
Are all sat-navs going to fail in 2010? Jump to Comments
sat_nav_fail.jpg?w=300&h=200 Sat-nav systems could become defunct next year, according to a report from the U.S. Government.
It reckons a lack of investment and development into the U.S. Air Force’s GPS (Global Positioning System) will cause the failure.
But the U.S. Air Force said sat-navs will carry on working as normal. So who’s right?
I’ve been meaning to buy a sat-nav for some time due to my girlfriend’s “interesting” map-reading skills.
There’s no doubt reading a map can be more rewarding, but the convenience of using a sat-nav is a welcome one.
But recent claims from the U.S. Government’s Accountability Office (GAO) concerned me slightly. It warned the 20-year-old Navstar GPS system is in urgent need of an upgrade.
The GAO criticised the U.S. Air Force Space Command for offering the service for free, and said the lack of investment meant both military and civilian systems could be affected.
Apparently the GPS system overran its budget by £562 million and the next satellite is due to go into orbit in August 2009 – almost two years behind schedule.
“It is uncertain whether the Air Force will be able to acquire new satellites in time to maintain current GPS service without interruption,” the GAO said.
But the U.S. Air Force Space Command left a comment on Twitter declaring there is nothing to worry about.
“Be assured, the issue is not whether GPS will stop working. There’s only a small risk we will not continue to exceed our performance standard.
“Since 1995, GPS has never failed to exceed performance standards,” the U.S. Air Force Space Command said.
Drivers across the world will be affected if sat-navs fail to operate in 2010.
If the satellites do go down, a new EU sat-nav system called ‘Galileo’ could be in big demand when it goes worldwide in 2013.
Until then, I’m going to put my faith in the U.S. Air Force and take the plunge with a sat-nav.
This does worry me, because I have had simliar problems with my work's sat nav, even on clear sunny days.
Jul 06, 2009 | Garmin n?vi 755T Car GPS Receiver
My garmin c340 will no longer connect to satellite
Hi
Try updating at Garmin Here
This can resolve sat problems
Regards.
Apr 15, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin 260w won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin aera 500 Color Aviation GPS Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
