Question about Datamax I-4208 Thermal Label Printer
Steps on how to change a IP Address on a Datamax I-4208
    Master:
  • 451 Answers
You need to go to menu mode configuration. 1 will go up 2 will go down the menu items ent is the select.
go to nic adapter and go to wired dhcp you can disable dhcp there and configure the IP address
Posted on Feb 22, 2012
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
  • 67 Answers
SOURCE: datamax dmx-i-4208 (ribbon fault)
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
Posted on Nov 07, 2009
SOURCE: 4208 Datamax M Class printer Problems
After changing the size of your labels the printer needs to measure the new label length. Press the feed button for four seconds (wiht new labels loaded & printhead locked down). If this doesn't fix your problem you need to correctly position the media sensor.Make sure the short white line on the media sensor is above the label gap.
Posted on Aug 21, 2007
  • 4 Answers
SOURCE: the printer is datamax I
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Posted on Nov 18, 2010
SOURCE: password reset for datamax i 4208 printer. locked
sysadm
Posted on Feb 18, 2011
How do i find my ip address
Please tell your printer model. If the printer has a touch screen support you can view the ip from network settings option on the printer. You can also see the ip of the printer by connecting it to your computer through a normal cable and going to its properties.
Aug 27, 2014 | Datamax DMX-I-4208 Label Printer
HOW TO FIND THE ip ADDRESS ON A DATAMAX i-4208
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Jun 19, 2014 | Datamax I-4208 Thermal Label Printer
How do i find IP address DATAMAX
Just print out the configuration through test button
May 16, 2014 | Datamax I-4208 Thermal Label Printer
Change ip address
On printer front panel, press Menu, go to System Settings, Communications, NIC Adapter.
Feb 26, 2013 | Datamax DMX-I-4208 Label Printer
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
Can I print labels using DPL to a networked Datamax I-4208 using C#.NET?
greg babcok: You can do printing via tcp/ip packets or using Windows spooler. I have some example in vb.net
Roberto Martinez
padrino99@prodigy.net.mx
Apr 27, 2011 | Datamax I-4208 Thermal Label Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 Thermal Printer.
I have seen quite a few bad nic cards from Datamax, and that may be the problem.
If you can set the card from the printer, then it is seeing the card as it reads directly to the processor when inserted. But the card can still be bad if you cannot ping from the outside.
Jan 12, 2008 | Datamax M-4208 Thermal Label Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
2,417 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
