Question about Frigidaire Affinity ATF7000E Front Load Washer
When turning on it goes to pause - Frigidaire Affinity ATF7000E Front Load Washer
When i try turn my frigidaire affinity dryer on it buzzes and goes to pause
Good Morning friend, thank you for your post!
From the information you have provided your Frigidaire dryer is buzzing and goes on pause when you attempt to turn it on. This could be a possible issue with your door latch, door strike, or control panel. If you dryer shows pause that means there is an interruption within your cycle. I would advise to look over your door latch and strike to see if there is any apparent damage to either component. If both components appear to be working properly I would advise to have a technician come out to review your control panel. I hope this information has been helpful to some degree. -Matt
Feb 17, 2015 | Frigidaire Dryers
Keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Nov 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
RCA TV D52W136D
unplug your set leave unplug for 30 min plug back up any change?...this reset it.. if still not come up may have other issues
Nov 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Frigidaire Affinity ATF7000E Front Load Washer Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
