Bush 30W iPhone/iPod Speaker Dock operating instructions
I need the operating instructions
SOURCE: does the aj300D speaker dock charge and play the new iPod nano 4t
nano 4th does not support firewire anymore, best option is to bring your AJ300D back to where you bought it. Philips claim that nano 4th is supported is not true.
Posted on Dec 29, 2008
  • 73 Answers
SOURCE: ipod dock piece where ipod slides onto has been
Not likely unless your really good with soldering irons and superglue or it is COMPLETLY seperate (In other works the dock fully seperates from the speakers) then you might be able to order a new dock piece
Posted on Apr 22, 2009
SOURCE: i need to open a JBL onstage II speaker system to
you have to remove the 3 sticky pads in at the bottom of the speaker and there you will expose all the screws that need to be removed...there is also one where the batteries go
if you have any luck replacing the ipod dock let me know please
Posted on Nov 15, 2009
  • 6 Answers
SOURCE: Sony ICF-CS10iP iphone/ ipod dock will not charge
connectors on the dock are probaly faulty return to sony to get repairedv (it will probaly cost) contact sony to arrange
Posted on Feb 25, 2011
SOURCE: memorex travel speaker with ipod
Its actually not the play/pause button to get it to move between hours and minutes. It is the "Time Set" button you need to press. So, hold the "Time Set" button until the time flashes. If you want to go between 12 hour and 24 hour time, then hit the the ">>" button. To set the hour, press the "Time Set" button and now only the hour will be blinking. Use the ">>" or "<<" button to adjust the hour. Press the "Time Set" button again, to move it to the minutes. Use the ">>" or "<<" to adjust the minutes. Then press the "Time Set" button to finish setting the time. You can do this with the "Power" switch on or off.
Posted on Jul 31, 2011
How do I get operating instructions for this sound bar
1. Plug it into a power outlet and turn it on.
2. Put 2 AAA batteries in the remote control.
3. Dock your iPod or iPhone into the docking connector.
4. You can hook up the sound bar to your PC (from the RCA(L/R) audio output on your TV to the RCA audio input on the bar) or to your PC (from the headphone jack on the PC to the LINE IN jack on the bar). Obviously, you can hook it up to both TV AND PC only if those two are located close to each other.
5. Using the remote, select the audio source/input you want to listen to: iPod/iPhone, FM Radio (an FM tuner is built into the sound bar), TV or PC.
Hope this helps.
Dec 20, 2014 | Apple Ilive Itp100b 2-channel Speaker With...
What i pods fit this travel dock
  • Compatible with iPhone 4S, iPhone 4, iPhone 3GS, iPhone 3G, iPod touch (2nd, 3rd and 4th generation), iPod nano (2nd, 3rd, 4th, 5th, and 6th generation), iPod classic, and iPod with video
Aug 24, 2013 | Memorex Travel Speaker with iPod Dock...
Dropped my yamaha PDX-30 and it wont work anymore. compartment where the cable connects is cracked. what can I do to fix it ?
it is not broken forer, relax, there must be only dissconnection of wire ,, check the flow of current through the wire catusiously, better take it to local vendor he'll fix it for cheap buks
Jun 05, 2012 | Yamaha Pdx-30 Ipod/iphone 30w Dock Speaker...
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
The altec lansing inmotion does not charge my new ipod nano.What I can do
Maybe this could be the solution...
Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
Oct 30, 2009 | Altec Lansing inMotion® iM500 Docking...
Directions say it charges and syncs. When I
Look at:
Oct 09, 2009 | Altec Lansing inMotion® iM500 Docking...
104 people viewed this question
 Grubhead
Grubhead
