Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I have a Jandt lite 2 heater and went to fire ir up and the gas valve starts clicking real fast and the unit fires up but shuts down within a minute as the gas valve continues to click till it shuts down.any one know what the problem is?
    Top Expert:
  • Jandy Master
  • 8,163 Answers
Replace pressure switch or copper tube is plugged
Posted on May 28, 2015
  • 61 Answers
SOURCE: heater will not heat
If you dont smell any gas make sure that all gas valves between the heater and the main gas meter are open, and the gas valve in the heater is in the on position. Try cleaning out the nozzles that the gas comes out of. Sometimes they can build up with cobwebs.
Posted on Apr 09, 2009
  • 139 Answers
SOURCE: pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Posted on Aug 11, 2009
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
  • 115 Answers
SOURCE: Heater starts gas and ignite works for a few
it is the flame sencor is bad.it is a stick looking tube near the flame. it has one or two wires on it . when it does not sence flame it shuts down.
Posted on Dec 21, 2010
Require millivoltage for gas valve on raypack pool heater
clean burn tube to pilot generator replace generator and make sure all wires tight
Apr 12, 2017 | RTO Pressure Switch 3902 Swimming Pool...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
We have a jandy Lite2, when turning on, you hear the igniter firing, and seconds later everything stops and the pool is not being heated!!
Does the heater fire up at all? If the igniter is ticking that means that it is trying to fire. The problem can be as simple as a clogged pilot orifice. Otherwise the gas valve may not be opening due to a bad wire telling it to open, or the gas valve has failed.
Also, double check that the gas cutoff valves at the gas meter and the one next to the heater are open, valve handle in line with pipe. Closed, the handle is perpendicular to the pipe. They have been known to shut themselves!
Jan 15, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
We have a Laars Lite 2 which will fire and run for about 5 minutes then shut down. We changed the 135 and 150 limits as we noted a drop from 24 to 14.6 V. It appears to me that the unit is over heating. We...
make sure correct gas pressure if too low it will soot up and overheat sounds like transformer is going should be 24 volts if not pressure switch wont stay on also check the manual bypass by plumbing side if spring is bad water will not go through the heater correctly
Jul 02, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
I have the Mr. Heater Big Buddy and it has been giving me trouble lately. After two years of flawless operation, the unit constantly shuts down, after only a few minutes of operation. I use a 20lb cylinder...
tough one doug, easy way is buy a new gas valve under red knob.
harder to try to fix old one.
the stopage of your mister heater is caused by the pilot lite going out
so what is causing the pilot lite to go out? that is the problem.
inspect the pilot lite and its gas supply tube all the way up to the main gas valve under the red knob control valve. unscrew the pilot lite gas supply line from the main gas control valve and clean out interior of gas supply line all the way through the pilot lite orfice to the open air. It must be totally clean, .like new, including the pilot
orface, in order to work properly.the least obstruction might deflect
or restrict the gas flow & cause poor or no opperation
when you unscrew the pilot lite gas supply line from the main gas valve,with a flashlight, look inside the hole, that the gas supply line was removed from.
It may be full of gunk that has to be removed for gas to flow properly. try blowing out with compressed air with a straw tipped blow gun. you may need carburator cleaner to loosen the gunk ,if gunk is present.
WARNING:::
If you use carb. cleaner, it burns like gasoline, so make sure any carb cleaner is blowed of with compressed air or blotted up with facial tissue & totally dried up & removed before firing up mr heater, in order not to catch mr. heater on fire.
If a lot of gunk is in the outlet of the main gas supply valve,you will
need a pocket screwdriver,a paper clip and maybe a sewing needle in order to pick out the crud.
It must be totally clean inside, like new, in order to have a chance at working.
It may still not work if more crud is inside the main gas control valve where you can not get to clean it out.
if you reach the point where you decide to buy a new main gas control valve, first try disassembling your old main gas control valve and cleaning it out,like rebuilding a carb, and reassembling it.
If this works,you dont need to buy a new main gas control valve
and have saved 30.00 plus 12.95 shipping
if it dont work,all it cost you was time & angervation.and you still need to buy a new main gas control valve.
Jan 04, 2010 | Mr. Heater Big Buddy Heater
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
139 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
