A 266 Mhz system bus processor is installed. This processor is not supported on this system board and will run at reduced processor clock speed.
ECS model- p4m890t-m
map9966
  • 2351 Answers
SOURCE: asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Posted on Jun 02, 2008
  • 6 Answers
SOURCE: Intel 845 GVSR
systeam hangs duing win xp xp2 installation. win xp sp1 works fine. pl help
Posted on Oct 30, 2008
  • 341 Answers
SOURCE: EP 4plai motherboard -Processors
To get more than max speed from your board you will need to install the fastest chip your motherboard supports and then overclock it.Send me another post if you are interested in going further.
Posted on Dec 04, 2008
leecom72
  • 4806 Answers
SOURCE: The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
Posted on Jul 22, 2010
  • 11800 Answers
SOURCE: Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the
Maximum of 1 GB per slot.
Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
Yes, they will work, but not very fast. They should be used only as a last option.
Posted on Aug 03, 2010
Testimonial: "gud but i need a bit clarification for terminologies and methods he said."
53mhz system bus processor is installed this processor is not supported on this desktop board and will run at reduced processor clock speed system performance will be impacted intel r pentium iv processor...
Determine the manufacturer and model number of the system board. Locate the system board manufacturer's website. Check for a list of supported processors for your system board. If it is on the list, you may need only to update the system board firmware. If you have questions about the suitability of the processor / system board combination - contact the system board manufacturer's tech support group or technical forums that they may be operating on the site.
Do not attempt to apply a firmware update file to any system board for which it is not intended! Doing so can cause irreparable harm to the system board.
I good luck!
Sep 04, 2012 | Intel Computers & Internet
I need RAM for an Intel E210882 D865GBF motherboard (DIMM, single notch more or less in the middle of the board). What do I need?
It appears your board was manufactured sometime around 2003.
It has supported front side bus speed of 800, 533, and 400 MHz, and has a capacity of up to 4GB Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this desktop board
Hope this helps.
Feb 22, 2011 | Intel Motherboard
Hi, i was windering if it was possible to use 168 pins pc133 memory modules instead of the ddr 266 into my P4B266 Motherboard, since they have the same size and work at the same frequency. In the manual,...
*********** board will suport for 133 bus speed memory.Memory Size is not the matter,what ever you can install in the mother board,may be 128/256/512,but ensure the bus speed .It wont be more than 133 mhz.,then your mobo can not support.If you have SDR 133 bus speed ram you can install .
*********** board speed is 400 mhz,you can change 478 pin any intel processor,for better performence but the bus speed would be 400 mhz or bellow 400mhz,both will be suported.
For detail follow bellow the link.
http://www.firingsquad.com/hardware/p4b266/default.asp
Hope it will you.
Jan 08, 2011 | ASUS P4B266 Motherboard
I have a Syntax K7 SV400 motherboard. The board will post but will not install the os. The bios recognizes the cd drive and the hard drive. When I try to install Windows 2000 Pro the cd drive spins and I...
Nothing, first try the disk in a working pc & see if it auto-runs in windows,if it does then try a different ribbon cable on the cd drive. If it doesn't then the disk is dirty or damaged. Also, not accusing you but windows 2000 is probably the most burned copy of windows around. If this is the case, go to whoever you got the disk from & tell them to re-burn it at 4x if possible but no faster than 6x, then the disk will work. As far as the bus speed is concerned(the jumpers), if the processor is a 100mhz, that's all the faster it will operate. Especially on older pentiums,which it sounds like you have. Now the processors will go to a slower speed, like 166 to 100. Keep in mind when switching cpu's you must set the jumper to the matching or slower speed or it will not post. Also, that speed is half what the actual clock is, meaning, 100 is 200,133 is 266, & 166 is 333 mhz. So if it's a socket 7 or 380 board, you can run an AMD or Cyrix cpu instead of the pentium & use whatever speed you'ld like because AMD products back then didn't lock the multipliers. Also on those older boards, some won't run certain ram speeds, like if the board has 100mhz ram it may not like 133 much. Ram wasn't very backward compatible back then.
May 14, 2010 | Computers & Internet
Restart computer even when bios is open
Check your Processor cooling system.If the cooling is not proper or if the processor is not working properly then the system will restart on its own with in few minutes of boot up process.Also check if there is any infection.
Jul 10, 2009 | Intel Computers & Internet
PZ TELL ME ABOUT WHICH PROCESSOR(CLOCK SPEED) SUPPORT INTO 845GLLY MOTHER BOARD
845GLLY supported processors:
1.6GHz to 2.4 GHz Pentium 4 processors with system bus frequency of 400 MHz, for more information follow this link: http://support.intel.com/support/motherboards/desktop/d845glly/sb/cs-012859.htm
Apr 29, 2009 | Computers & Internet
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
584 people viewed this question
David Payne
David Payne
