Question about Canon Office Equipment & Supplies
Canon MP610 Printer When automatic duplex printing in landscape orientation, the reverse side is printed upside down. Duplex Printing in portrait mode works fine. Can you help?
  • Anonymous Mar 13, 2014
    printer is set to automatically apply duplex to multi-page prints. How do I stop that?
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
  • catnip1977 Aug 20, 2010
    This worked just as described. Thanks for posting!
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
How do I print on both sides of the sheet?
If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
Office 2007
  • Open your Office Document
  • Click on the Office button in the top left corner of the screen officebutton.gif
  • Click Print and select one of the printers that will perform duplex printing
  • Click on the Properties button under the Layout tab
  • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
  • Choose Long Edge If your page is set up as Landscape
  • Choose Short Edge . Click on OK again to send your work to the printer
Other Applications
  • Go to File and Print
  • Select one of the printers that will perform duplex printing
  • Choose Long Edge if your page is set up as Landscape
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My book fold booklet is printing upside down when duplexed!
You may need to tell word you want your printer to flip on the short side and not the long side. With my Canon printer I get a drop down menu IN WORD (not printer setup) that gives choice of: print one side; print two side flip on long; and print two sides flip on short.
Jun 02, 2010 | Microsoft Office Word 2007 Upgrade Version...
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Jul 17, 2008 | Canon MP610 Photo All-In-One Printer
Duplex printing
I think you given the wrong printing on one side. So Check the page orientation and do the printing
Sep 29, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
749 people viewed this question
old marine
old marine
