Question about Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner
My S1500M scanner duplicates text when it scans - effectively, adding text to the bottom of each page. I am getting the same problem on my other fijutsu scanner, suggesting a software problem. But m
Text duplicated is always the last part of a page, and the image after the scan will have at the bottom a replicated portion of the page scanned. Same thing has begun happening on the smaller scanner I have, also a fujitsu. Especially common if scanning multiple pages, nbut has happened with a single page, too.
HITESH
  • 20 Answers
SOURCE: Scanning trounleshooting
Open the paper feeder tray gently. see the rollers which intake the paper. Clean softly those rollers and tray with a dry medium. Pleasedo not touch any senser there. Read the open instruction from manual.
Posted on Aug 25, 2007
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
  • 48 Answers
SOURCE: Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Posted on Jun 27, 2008
mohanchennai
  • 490 Answers
SOURCE: fuitsu 5120c
Please clean the glass with Isopropyl alcohol. Dont use solvents. S. Mohan, India
Posted on Jun 07, 2009
TechSatya
  • 104 Answers
SOURCE: the fujitsu fi-5110C won't scan all pages just
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Posted on Jul 19, 2010
Unable to Scan to print
As from your question it is understood that, you have not correctly uninstalled all the software and drivers related to Fujitsu Scansnap S1500M printer from the computer. So to help you uninstall it correctly and reinstall it again, please follow the step-by-step instructions mention under 'Uninstalling on a Windows OS' on page.no.355. and to reinstall it follow the instructions mention under 'Installing Scansnap Manager on Windows' on page.no.47 from the user manual link given below:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/s1500_s1500m_ops-guide.pdf
If issue persists, you are advised to contact printer manufacturer from the below link:
http://www.fujitsu.com/global/support/
GuruAid.com
Mar 16, 2016 | Fujitsu ScanSnap S1500M
How do I stop the scanner from scanning the blank back of the page?
Somewhere in the settings for the scanner it is set to scan both sides. You need to go into the menu and change to one sided scanning. Another possibility is that you could be putting the document to be scanned in backwards.
Jul 30, 2014 | Fujitsu ScanSnap S1500M Pass-Through...
The scanner is making a noise while scanning
Hello Rita,
The noise produced when the gears in the ADF upper unit is worn off. You are recommended to contact a Fujitsu expert for replacement of the faulty gears. You may also contact scancare.bbs@gmail.com for more details.
Thanks,
ScanCare
May 22, 2013 | Fujitsu ScanSnap S1500M
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
I want to scan text from a page.help me
While you are scanning an Doc, you need to change the scan type from Image to Doc.
Jul 16, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Jun 11, 2009 | Ricoh Aficio IS420 Flatbed Scanner
My Canon DR-9080 scanner is duplicating pages, when it is not set to do that, it is not every page but consistently the 1st page and 15th page. Have uninstalled drivers, re-installed drivers, changed...
Very likely it is the software that you are using. I would run virus scan like Mohan suggested, and then test again. If the problem is not a virus, then I would uninstall the scanning program and reinstall it...or contact the software manufacturer if you have a maintenance agreement with them. There is a good free downloadable high speed document scanning software available if you want to load it and verify that it is a software problem.
Jun 01, 2009 | Canon DR-9080C Path-Through Scanner
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
When scanning, the scanned page is not readable from a third of the page down to two thirds of the page.
It is important that the item you scan comes in close contact with the scanner glass. If the resulting scanned image is not clear, check to see that the item is in full contact with the scanner glass. The scanner uses optical character recognition (OCR) to convert text on a page to text that you can edit on your computer.
  • If you scan text but cannot edit it, make sure that you make the following selections during scanning:
  • Scanned text might not appear on your computer exactly as it appeared on the original, especially if the original contains faint or smudged text. For example, some characters might be incorrect or missing. As you edit the text, compare the scanned text against the original, and then make corrections as necessary.
  • To change text scanning options, click the Scan Document Settings button in the initial What are you scanning? screen.
  • The OCR software is installed by default when you install the HP Scanning software during scanner setup. If you use the Custom option when installing the software, you can choose not to install the OCR software. Try reinstalling the software using the default install options.
  • Email to jdiaz@coretec.us
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Nov 07, 2008 | HP Office Equipment & Supplies
Open Questions:
See all Fujitsu ScanSnap S1500 Instant PDF SheetFed Questions
Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
