Question about Xerox Phaser 8560/YN Printer
Xerox phaser 8560 printer is saying waste tray missing but it is not
We were given this printer, as owners were going abroad, it has been sitting for around 6 months boxed up in garage, now it starts ok but then stops and message says waste tray is missing but it is there, have tried turning on /off and taking the tray out but still wont get past this message, any idea's? thanks
  • kerry_golbou
    kerry_golbou Feb 22, 2012
    thanks Jeffrey, but yes the printer panel is pointing to the waste tray on the right side of the printer, i think the sensor inside the printer has either moved or comeoff, as you can see something when you shine a torch inside, but its too far inside to see and get to, but thank you for your answer
  • 669 Answers
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Posted on Feb 22, 2012
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
  • 17 Answers
SOURCE: xerox phaser 8560 close control panel error
Bad control panel. Xerox will replace for free (800 635 8100) call and ***** to get it for free (They had a "LOT" of defective panels)
User installable.
Posted on Aug 21, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
How do I print on 4X6 photo paper on the Xerox Phaser 8560
To print 4 x 6 on a Phaser 8560 you can only use the MPT and you can't duplex. When you load the paper into the bypass, the screen will pop up options for paper size and type. The closest match to 6 x 4 is A6 but the tray will know that the size is wrong if you select it. Therefore, you must select 'Custom Size' and input the size in whatever units the printer requests, either inches or millimeters depending on your printer settings.
Hope this helps.
Nov 28, 2010 | Xerox Phaser 8560MFP Laser Printer
Does anyone know fault code 37,018,45: 13830 for Xerox phaser (Service needed)?
This is from the service manual
Harry
8500/8550/8560 PEST description
37,018.45: Main Tray Deskew Clutch
Disconnect.
The Main Tray Deskew
Clutch is not drawing the expected
power
Aug 07, 2010 | Xerox Phaser 8560MFP Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560/YN Printer Logo
779 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
