Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Vizio L30WGU sound no picture problem
If you can provide pictures/description of what you did to get your tv working I would really appreciate it as my set went dark this morning. I'm thinking of buying a refurbished inverter board as a new one is $330 according to Vizio (part no. V08914430104) through www.vancebaldwin.com
  • 362 Answers
SOURCE: I'm trying to register my new vizio television
https://crm.admin.waca.com/WaCA/WarrantyCenter/registration/secure/Vizio/Registration.jsp
Click on this link, if it dosn't work Place your cusor on the link and right click, select copy, go to your browser, place cursor on the address bar, right click, select paste, press enter.
Let me know if it dosn't work Please rate this solution.
Lone99star
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
  • 4234 Answers
SOURCE: Vizio GLV47 LCD HD TV No Picture No Sound?!?!?!?!?
Without seeing the set and takig some measurements, I can't say for sure where the problem is, but the part info is listed below. These can be purchased through tritronicsinc.com. Please note that these boards have a "core" cost. This means that the "core" amount will be refunded to you once the defecive board is returned.
Dan
Power board: 0500-0510-0340 Cost: $102.97 Core: $10.00
Main board: 3647-0072-0150 Cost: $202.68 Core: $40.00
Posted on May 01, 2009
iseeu2
  • 4 Answers
SOURCE: vizio vw42l, the vizio light turns from ornage to
Does LCD screen backlight come on? If so proceed....
USE:CAUTION WHEN DOING THIS....
Try this if repairing yourself...find power supply, small board with no cover over it...check voltages on output pins/plug/connectors (white plugs) three in a row...
1 Plug has 24Volt supply..1 has 12Volt supply and 1 has 5Volt supply when read to ground (screw that holds board in) if you have these voltages it's a safe bet it's the main control board...I just replaced mine and it fixed a problem like yours.
Posted on Sep 02, 2009
  • 8457 Answers
SOURCE: I have a 42 inch vizio VW42L and a few months
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Posted on Sep 26, 2009
Tv would seem to lose connection ... the screen picture would go"in and out" and then dark, and then come back on. Now the TV won't "turn on" even though the power indicator light is on.
Now,tv turn on have flashes picture few sec.dies and stiill have sound?Yes,than 1 or 2 a long LCD inverter boards are dead. Those 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.No picture or sound at all?The Tuner board is dead,that the board,where the incomming broscasting signal cable plug into it dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards or the Tunner board for the replacement.
Sep 19, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
No picture will show on tv but comcast and sound are working
Nah, that's not it. It's a conflict between the box and the TV. Does the picture appear some times, and not at other times? And does your TV work whenever you use a VCR, DVD, or other separate console (e.g., Wii)? If so, it's not your TV that is the problem.
Oct 24, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
I HAVE A VIZIO L30WGU IT STOP WORKING IF I TURN IT ON THERE IS NO PICTURE OR SOUND, ONLY THE FRONT LIGHT COME ON. WHAT CAN BE THE PROBLEM OR WICH PART TO REPLACE.
the power pcb .vizio to my knowledge does not
supply parts on most models.to find out go to
encompass.com and put in your model#.
Jul 17, 2009 | Televison & Video
Vizio glv47 powers up no then no picture
We have the same problem and purchased a power supply to see if it would fix the problem. It didn't. We are now in the process of buying the main logic board and we will let you know if this fixes the problem. It seems like it is in sleep mode but doing the steps to get the tv out of sleep mode does not work.
Feb 22, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
Jan 10, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Picture problem
i have vizio that turn on, but no picture, and the invarter light is on and it won`t turn off.
Oct 20, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Picture goes black, but audio stays on ????
Well i have the same tv , and when i took it apart i switched a few wires around and i managed to get it working again, i can send some pictures of what i did because, i really had no clue what i exactly did by switching the wires.
Jul 26, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
344 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
