Question about Sunbeam 5891 Bread Maker
How to remove bottom panel of sunbeam breadmaker
It seems that there is something wrong with the motor or maybe the drive belt. I removed the 5 screws at the bottom but the panel wont come off. Any advice?
Remove the screws in the oven and the screw holding the heat element.
Posted on Feb 02, 2013
  • 3 Answers
SOURCE: how to change the belt?
Yesterday I have the same problem: the belt of my Sunbeam bread machine broke. My problem is I didn't find a belt replacement yet. Once you have a replacement, to change the belt:
1. Unscrew the 4 screws located at the bottom of the machine
2. Open the top of your machine. You'll see 8 screws that put together the bottom of the chamber with the walls. You need to unscrew those screws with a very long screwdriver (caution with the heating element).
3. There is one screw attaching the heat element to a ceramic rectangle to the opposite side of the chamber. Unscrew this TOP scew.
4. Once all those screws are out you have to force the bottom piece of the machine with a flat screwdriver. This bottom is attached to the top part with some clips on the front and the back of the machine.
5. Once you open the bottom "cap", caution when separating both pieces. You will find a flat cable that is connected from the computerized pannel to one card attached to the bottom part of the machine. This plug located on the card at the bottom part of the machine have one drop of glue securing the two parts. Twist off the drop of glue and you can disconnect the cable from the card without any problem.
6. Once both parts (top and bottom) are separated you can proceed unscewing the 7 screws that fix the motor to the plastic bottom "cap". You need to do that to access the bellt area.
7. To place a new belt just unscrew the bolt that fix the large "circle". Take away the bolt, the 2 washers, the rectangle one and the "circle". Place the new belt around the small circle (motor) and the big circle. Return the big circle to its original location (align the square part of the wheel with the square part of the screw) and push it to set it in place. Return the rectangle washer, the flat washer, the pressure washer and screw the bolt to secure the pieces.
8. Put all the pieces together in reverse order: *screw the motor to the bottom plastic piece; *connect the flat cable to the card; *push the top and bottom pieces together and until all the clips fall in place; *screw all the little screws to the botom of the inside chamber; * screw the little/long screw to fix the heat element to the ceramic rectangle; *screw the bottom screws.
AND ENJOY YOUR MACHINE! :0)
Posted on Mar 08, 2010
greenspan
  • 1734 Answers
SOURCE: INEED TO DOWN LOAD MANUAL FOR A SUNBEAM BREADMAKER
Find that here for direct download:
http://manualfox.com/link/sunbeam.htm
Posted on Aug 02, 2009
EwingElect
  • 276 Answers
SOURCE: Instruction manual Sunbeam Model BM7800 breadmaker
Hi!
Go to http://www.sunbeam.com.au/Pages/Support/ManualSearch.aspx and you can do a manual search and download a PDF. If the model is superceded check the "Show me back catalogue items" box.
Posted on Mar 25, 2009
EwingElect
  • 276 Answers
SOURCE: "Err" message on Sunbeam breadmaker
Checked the manual but no info in http://www.sunbeam.com/Manuals/MANUALS/005891-000-000_43_4357793.PDF
Would suggest checking with your local Service Center, locatable via http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Posted on May 25, 2010
  • 332 Answers
SOURCE: Dear Reader, I am looking
AMAZON OR THIS COMPANY
http://www.espares.co.uk/parts/tumble-dryers/hoover/ppc160-80/p/1088/107/0/677661
Posted on Jan 12, 2011
How do I get a manual
http://kitchen.manualsonline.com/manuals/mfg/sunbeam/5891_1_2.html
Dec 25, 2015 | Sunbeam 5891 Bread Maker
Sunbeam bread maker struggling during mixing and is sporadic. When I turn it on without the pan the bottom unit turns so I don't think belt. And seems to do fine when no ingredients in pan. But once I put...
yes, a good chance of a week motor. However, try using cooking oil, lard ect. to lubricate the mixer paddle from the bottom of the pan. Also check to make sure no debris at the same location is wrapped around the shaft. I have had to lubricate mine before as it seems to get stiff from time to time.
Jan 20, 2015 | Sunbeam Kitchen Appliances - Others
How to replace sunbeam bread machine belt model 5891
Here is how it's done on machines that have a removable panel on the bottom:
Sep 27, 2014 | Sunbeam 5891 Breadmaker Home Bakery Bread...
Sunbeam repair manual
Hi...Before trying to take it apart, you should verify that the paddle in the bread pan is moving or not. Take the pan out of the machine and try to turn the paddle by hand. It should turn free and smooth with little effort. If you can't turn it by hand then the bearing is frozen and the bread pan needs to be replaced. (no fix for it).
If the paddle moves freely, then the belt in the bottom of the unit is loose or broken. Reply to this thread and we'll help you out!
Hank
Jul 26, 2014 | Sunbeam Kitchen Appliances - Others
My sunbeam 0091 breadmaker does not knead. If I go to 8 which is knead dough cycle it comes makes noise but nothing else.
Yes. Hopefully your machine has a removable bottom panel. remove the panel and get your old belt off and make note of the belt code. It will look something like this: STS 60 S3M471 I sell replacement belts and you can visit me at breadmachineshelp.com
Mar 02, 2013 | Sunbeam 5891 Bread Maker
My Sunbeam bread maker will not knead
If your machine has a removable panel underneath. Remove the pand and paddle first and then Remove that panel by using a screwdriver ( be sure unit is unplugged first) by turning it on its side or upside down. Once you have the pane off if the drive belt is broken contact me at breadmachineshelp.com
Feb 11, 2013 | Sunbeam Kitchen Appliances - Others
Broken belt on Sunbeam bread machine Model 5891
I sell replacement belts. Visit me at breadmachineshelp.com and include the numbers & letters off of your old belt. The numbers will look something like this: STS 60 S3M471 OR STS 80 S3M 514 or you can just email me the belt code to my email address which is daryl441@msn.com
Feb 10, 2013 | Sunbeam Bread Maker, Large 2lb Model 5891,...
My sunbeam breadmaker will not mix the dough. The detachable mixing arm on the bottom won't spin. I had to quickly mix the dough and put it back in to bake
If you are feeling handy unplug your machine, turn it on one side and remove the bottom panel with a phillips head screwdriver. You may find your drive belt has come off or broken. If that is the problem you may be able to find a replacement for it from Sunbeam, or I may have one that will fit it.
Aug 02, 2011 | Sunbeam 5891 Bread Maker
How do you get the bottom off of the Breadmaker
I too wanted the answer to this question. Remove all the screws retaining the oven liner, you can then lift the oven liner out and the top plastc cover easily unclips from the bottom. To access the drive belt, remove the screws holding the chassis to the bottom cover. All that was wrong with mine was a loose retaining nut on the large driven gear - good luck!
Jan 11, 2010 | Sunbeam 5891 Bread Maker
Sunbeam 5891 Bread Maker Logo
1,714 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
