Question about HP Officejet 5610 All-In-One InkJet Printer
WON'T EVEN TURN ON
I CANNOT GET IT TO EVEN TURN ON!! I TRIED THE UNPLUG DEAL. I TOOK IT OFF THE STRIP AND PLUGGED IT INTO THE WALL PLUG NOTHING!! HELP!! IS THERE A REPLACEMENT PLUG OUT THERE AND WHERE??
  • ttoonen Oct 29, 2008
    My printer don't come on and when the phone is pluged in the phone don't work.
    Scholar:
  • 32 Answers
Hi htmeross1 -
in case you have this problem in the future... here's a couple HP support links that might help:
this one is to a doc re: the printer won't even turn on:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=441125
this is to general support info/links for your model:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&docname=c01321436&product=441125&
hope these help if you ever need them again.
- JW50
PS - Note: If you try to go to this link from a site overseas and the web page will not come up, try adding "amp;" after each "&" in the URL.
Posted on Nov 04, 2008
Can anyone tell me why my Brother MFC-J630w wont turn on. I was using it earlier. When I unplug it & plug it back in, the light doesn't come on. It just makes a ringing sound.
1. Unplug the power code then plug it in again. Do this where it plugs into the wall and also do it where the cord plugs into the printer.
2. If the printer is plugged into a power strip, switch to off then to On.
3. If nothing else is plugged into the same wall outlet or power strip, plug in a lamp, for example, to see if it works. If not, the circuit breaker for the wall outlet probably needs to be reset. Circuit breakers are in the main electrical panel/box for your house. There should be one that is moved to the left. Push all the way to left and then push to right firmly until it makes a loud CLICK.
May 18, 2014 | Brother MFC 490cw Color Inkjet...
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
The computer won't turn on
You could be having any of several problems.
First double check to make sure no cords came loose - you may even want to unplug and replug the power cable both out of the computer and the wall.
If you do not have a loose cord, listen closely when you attempt to turn the computer on - is it making any noise? Do any lights come on? If not, you likely have a bad power supply.
If the computer does come to life, just no reaction on the screen, make sure your monitor is plugged in and turned on, and try unplugging and replugging the cord connecting the computer and the monitor.
If this still does not get it, you may be dealing with either a graphics card or monitor problem. If you have an alternate plug for the monitor to go - try that, or if you have a different monitor to use, try that.
This should either greatly narrow down or fix the problem for you.
Aug 24, 2011 | Computers & Internet
Hi my tv fell off the wall last night about three feet to the carpet now it won't turn on the amber vizio light won't even come on when I plug it in. I took it apart and nothing appears to be...
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Jun 25, 2011 | Vizio L32 32 in. LCD HDTV
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
DVR won't turn on. TV screen is black
This can be a variety of different things, ensure television is powered on, what color light do you see on the front of your DISH Network 311 receiver? The green light is the one you should be seeing if the receiver is in fact powered on. If the light is not on even after pressing the power button on both the remote & the receiver, then I would recommend checking the source from which the receiver is plugged in, is it plugged directly into a electrical outlet on your wall, or is it plugged into a power strip? If wall outlet, perhaps try a different outlet and see if that makes a difference, if it's plugged into a power strip or surge protector unplug from wall and unplug receiver from strip for 30 seconds and reconnect checking to see if issue has been resolved. While checking these things, I would also recommend double checking to ensure nothing may have become disconnected and that all cables are connected from the back of your receiver to the back of your tv and to the wall and they are hand tight. I hope this helps, if the issue is still not resolved please feel free to contact me directly or you can call our technical support team for further assistance @ 1-800-333-3474. My direct e-mail is Kirstie.Filosa@dishnetwork.com.
-Kirstie DISH Network
May 14, 2010 | DISH Network 311 DTV Receiver
Printer does not turn on - checked plugs etc - all OK It could be a problem caused by new cartridge being installed.
This just worked for me. Printer would not turn on, no lights, nothing.
Took cartridge's out, unplugged from computer and wall outlet. Waited 5 min. Plugged into wall plug first, printer turned on, plugged into computer and reinstalled the ink cartridge's and pc found new hardware ( printer ) and all was working after that.
Unplugging from wall socket and pc, was what I needed to reset it.
Jul 18, 2008 | HP Computers & Internet
HP Officejet 5610 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
