Question about Radio Communications
No receive&transmit base radio icom vhf ic-28H
  • 36 Answers
SOURCE: ICOM IC-A23 CL-ERR Problem
CL-ERR means that the "frequency database" in the radio has somehow become corrupt. You will need another radio to clone from and a cloning cable to clone from good unit to yours, or the programming software and a cable to fix this issue. An Icom radio dealer may be able to do tjhis for you to fix the issue.
Posted on Dec 29, 2007
SOURCE: icom IC-F1020 and icom ic-f3
cqham.ru
Posted on Apr 13, 2008
ALLEN CLARKE
  • 47 Answers
SOURCE: VHF Radio
Check ther frequency tuning.
Sounds like it is off frequency.
Is the VSWR on the aerial Ok
Posted on May 26, 2008
vrc_tech
  • 109 Answers
SOURCE: ut 40 and 50 tone squelch
Go to http://www.repeater-builder.com/icom/icom-ic-4ga-gat-ge-svc-man.pdf , there is a layout of the decoder in this pdf file. I hope this helps
73's de Patrick N5SLI
Posted on Nov 14, 2008
SOURCE: ICOM IC-A6 Feedback type interference
The problem is caused by the microphone preamp in the headset demodulating the AM transmission. Sordin MSA headsets also have the same problem. What you require is a headset with no electronics in it and a dynamic microphone.
Posted on Jul 01, 2009
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
Not transmitting
Contact ICOM service at www.icom.com, or take it to a marine radio service center.
Dear sir I HAVE VHF MARINE TRANSCEIVER IC-M34 for 2 years ago, suddenly, I can't receive any signal ( transmitting without receiveing ) but if I set the squelch to 0 level I can reveive signals and...
This is a front end issue that has to be remedied by a radio tech or the factory. The front end is the receiver and it takes special tools and equipment to test and calibrate it correctly,, The only thing you can do is check the ICOM page to see where it can be serviced.
Nov 27, 2017 | ICOM Informatique Floating Hand Held Vhf...
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
ICOM IC-28H very low sound from radio even thought volume is max
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
Jan 07, 2010 | Icom IC-R10 Handheld Scanner
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
