Question about Toshiba Satellite A305-S6852 Notebook
Locked keys B N M
Hears a key combination and B N M A crashed
How can I open a yescom wall safe in which the key is locked inside and no code has been programed in yet
Hi, One of my friends working in the hotel had told me about how to program Hotel Room Safes code. As you locked the key inside. Try to program the code. Press the red button on the back of the door near the hinge, release it and you will hear two beeps. After that, enter a code that you wish to use as a combination, and confirm by pressing the button.
Now try to open the safe, enter your combination code and confirm by pressing the button. You will hear a beep and the green light will light up. Within 5 seconds, open the door using the knob.
May 06, 2017 | Locks & Locksmithing
How do i reboot a dell optiplex 960 to factory settings if i cannot login?
How to enter BIOS?
1. Turn on or restart your computer.
2. Press "F2" to enter "System Settings" (BIOS) when the DELL icon appears.
Restore the BIOS to default settings.
Press "Caps Lock", "Num Lock" and "Scroll Lock" buttons to light up the corresponding lights on the keyboard. Then, press the following three combination keys:
Alt+E - Clear (Release) the interrupted resources and reallocate resources at next startup. After pressing the combination key, you will hear a sharp beep tone.
Alt+F - Restore BIOS to the default settings. After pressing the combination key, you will hear a sharp beep tone.
Alt+B - Restart the system.
Password clearing method 1: When the password input box appears, type in the password and press "Ctrl" and "Enter" simultaneously.
Password clearing method 2: Remove the PSWD jumper on the MB and start up the system. Set the password to empty in BIOS, shut down the system and reconnect the PSWD jumper.
Hope this method will help you otherwise check Dell Optiplex 960 Manual- https://guideusermanual.com/product-name-optiplex-960-manual&po=344822&lang=English for expert's suggestions.
Dec 24, 2016 | Dell Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I forgot my locker combination to a lock and and i cant open it.
how do i get the box open . the box is 5400D portable key storage i'm a realtor
Sep 17, 2008 | Master Lock 5400d: Portable Select Access...
Nutool SF10 electronic digital safe
Open the safe door and press the s key press the I key twice then press the red button on the inside of door near the hinges. you will hear 2 long beeps. press the s key and then the red button and you will hear a beep enter your combination up to 12 numbers then press the E key your combination is now set. Best of luck
Sep 05, 2008 | Computers & Internet
My master lock 1547 lock combination was changed and i cant open it
If you have the change key, you can insert into the lock and make a new combination. Only the Change Key witll allow you to change combination.
Artgirl
Jul 16, 2008 | Master Lock 5400d: Portable Select Access...
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Toshiba Satellite A305-S6852 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
