Indesit delay timer light flashing
Delay timer light flashes along with door lock light flashing does this mid cycle :(
  • Iamwhoiam123 Feb 22, 2012
    the machiene is a indesit wixl143 it does this randomly some times it will work fine but is playing up alot last few days :( any ideas on what could be wrong are much apreciated :)
MakikiChris
  • 84 Answers
SOURCE: Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Posted on Aug 12, 2007
  • 209 Answers
SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Posted on Sep 25, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: indesit washing machine, wil103
Sorry, meant to add, if you switch the machine off at the mains once you've cleaned out the filter (bottom right corener, front of the machine, behind a plate), leave it for 2 or 3 hours and plug in again, sometimes it works.
Mine worked again the first three times, but I think this time it's had it and it's engineer and pcb time.
Posted on May 13, 2008
  • 197 Answers
SOURCE: lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
Posted on May 09, 2009
After a few minutes into cyle delay lights start flashing
Light(s) Flashing/Blinking - Door Opened - Delay ... - Maytag
www.maytag.com/...light(s)-flashing-blinking...delay.../PH7053/
MaytagQuestion: Built-In Dishwasher - Light(s) Flashing/Blinking - Door Opened - DelayWash - Cycle Power. Answer. Product Symptom: Built-In Dishwasher - Light(s) ...
Sep 26, 2015 | Bush Dishwashers
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Lights flashing on indesit WIL123S
and replace.
May 09, 2009 | Indesit W 123 Front Load Washer
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Hi there, My Indesit washine machine is washing, but will not go onto a spin. The delay timer keeps on flashing after the wash and the door will remain locked. The only way to open the door is to turn...
Could be several causes for this problem. first & easiest to check is the filter located behind the kick plate at front bottom of machine, any bloackages in here will cause this problem. check this & get back to me
Thanks,
Nov 21, 2008 | Indesit Washing Machines
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
