Question about Nokia C3 Cell Phone
Keep searching for wlan - Nokia C3 Cell Phone
    President:
  • Nokia Master
  • 695 Answers
Make a reset to factory defualt settings for your mobileGo to phone settings then to factory defualt settingsBut first you need to save all your important data in the mobile Becuase this action erase all data on mobile.After the resetting is complete,the problem will be solved.
Posted on Feb 22, 2012
Cant connect internet, always try again
Hello katlenternal,
What you are having seems to a common issue with the Nokia C3. I had one and I had the same issue when I first got it. Unfortunately I had to keep trying several times before it connected. But when I finally got it to work, I use the same pattern when trying to connect. First off make sure you are trying to connect with wifi. At the home screen, click down and scroll through until you get WLAN and select it. Go to avaliable WLAN and find the network you want to connect to. Make sure the signal is strong. Once you click it, enter the password and it should say you are connected. Exit back out to the home screen. Go to menu and go to internet. Click on Home, and it usually it ask's search WLAN. So I go through the same process as mentioned earlier. Connect to your wifi network. Once connected try reloading again. Hopefully this should work. Unfortunately you will have to keep trying over and over if it does not work. It will work, you just got to be patient. Good luck.
-Joe
Aug 25, 2011 | Nokia C3 Cell Phone
How do i turn on my wireless on msi u130?
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
May 14, 2011 | MSI Wind U100-030US Laptop
I am using nokia e63 searching default after every 5 minutes WLAN and Headset/music stand etc. please suggest me the solution.
Pls click on the NO WLAN FOUND option ..... There you will find SWITCH WLAN SCANNING OFF option ....
Mar 15, 2011 | Nokia E63 Cell Phone
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
My nokia e72 shows a message select connection search for WLAN it is annoying I set all settings to never run and applied all solutions mentioned in discussion forrum site. what else can I do?
Go to phone menu, select phone settings, select connection then select WLAN, select NEVER to stop searching for any possible WLAN signal. thanks
Jan 08, 2011 | Nokia E72 Smartphone
No wlan
try this link to google for wlan
wlan drivers - Google Search
Sep 14, 2010 | Computers & Internet
Can't disconnect wlan on n95
Have you tried the settings to disable the wlan search?
Jul 27, 2009 | Nokia N95 Cellular Phone
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
Nokia C3 Cell Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
