Question about Boating
Rs125 seatalk to st6000+ - Boating
    Problem Solver:
  • 7 Answers
An RS125 can be connected to a ST6000+ with either NMEA or SeaTalk data connection. NMEA is easier IMO.
To connect via NMEA, the RS125 red wire would go to vessels +12 volts. Yellow would be connected to the NMEA+ on the back of the ST6000+ and the shield, green and brown would be connected to the NMEA - on the back of the ST6000+ display
When connecting your RS125 into an existing SeaTalk network it should be powered from the network and not the display. The red and green of the 125 connect to the course computer SeaTalk red. The yellow cable should be connected to your display SeaTalk yellow. Shield and brown of 125 should be connected to SeaTalk gray.
Page 4 and 5 of the RS125 manual have pictures. PDF File
Regards
Posted on Feb 22, 2012
Where can I download black & decker st6000 owners manual
Couldn't find one. Might this one serve?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CDIQFjACahUKEwi3s7mfpIvGAhVRMowKHbmUAP0&url=http%3A%2F%2Fwww.ehow.com%2Fhow_7484314_thread-black-decker-st6000.html&ei=wWd7VffOFtHksAS5qYLoDw&usg=AFQjCNFL3IyFWdUOOtb62OxVuFd6dzbi7Q&sig2=mPBwzo9n_QxBGoVh_P5efg&bvm=bv.95515949,d.cWc
Jun 12, 2015 | Black & Decker Garden
I can't find a replacement spool TF065 for my ST6000 trimmer/edger. My husband passed away, and there is no spool in the trimmer. Home Depot says there is none. You just wind it on by hand. I have...
Unfortunately, the manufacturer no longer carries the TF065 for the ST6000 trimmer/edger. No substitute is listed. The TF065 is no longer in stock at any of the parts stores that I checked. The Parts List and direct order information is available here: http://servicenet.dewalt.com/Products/Detail?productNumber=ST6000 .
You can try other Service Centers in your area to see if they have any spools remaining in stock. Use the Service Center lookup tool here http://www.dewalt.com/Find-Service-Center.aspx .
I wish that I had better news for you.
Jul 26, 2011 | Garden
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raytheon RC520 Powers up, but NO FIX appears on upper right corner of display.
If you can find the white junction box where the antenna is connected take a volt meter and measure across the red and ground wire, you should have 12 volts. Across the yellow and ground wire you should see 10 to 12 volts it should also vary. This will tell you that all DC voltages and the seatalk voltages are OK. I would next secure power to the antenna, leave it off a couple minutes and then try it again. If these suggestions do not help you may need to replace the 120 GPS. The new RS125 is the replacement for this unit.
Jul 06, 2008 | GPS
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
Boating Logo
119 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
