Question about HP OfficeJet 7310 All-In-One InkJet Printer
Send fax failed
I do not here a dial tone
  • 669 Answers
Plug a regular phone into the phone jack, if you still do not have a dial tone you will need to contact the phone company. If you do, then change the phone line going from the fax to the phone jack.
Posted on Feb 22, 2012
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
rakeshpramod
  • 234 Answers
SOURCE: HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
Have you checked with your service provider about sending fax from VOIP lines.
Because iam affraid HP does not support VOIP Services.
Even if you call HP Tech Support they will ask you to call your VOIP Service provider they should have a answer for that.
Because the HP Fax machine only supports Analog signals and the VOIP Services have Digital Siganls which the machine cannot recognise, So please contact your VOIP Services for the same to send send faxes because it is not the fax machine which cannot send fax it is your VOIP Service provider which has a problem.
Good Luck
Posted on Aug 31, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
Joed911
  • 4338 Answers
SOURCE: cannot send or receive faxes
How to dial *xx codes when faxing When sending a fax, it may be necessary to enter in a *xx code as the first part of the number. Follow the steps below to dial *99 when using a VoIP service. NOTE: Since the *xx code is an instruction to the phone system, this must be dialed live.
  1. To pick up the line on the HP All-in-One, press Start Black Fax or Start Color Fax without entering a phone number first.
  2. When you hear the dial tone, enter in the *99 code.
  3. Wait a few seconds and then enter in the rest of the number.
  4. The HP All-in-One will complete the fax as normal.
What can be done to help the fax transmission? The communication speed is a major factor in fax transmission over VoIP. Currently there are three speed standards.
  • Fast - v.34 which communicates at 33.6 Kbps.
  • Medium - v.17 which communicates at 14.4 Kbps
  • Slow - v.29 which communicates at 9.6 Kbps
Changing the Fax Speed Adjustment setting to Medium may improve your ability to send a fax over a VoIP network. On most HP fax products the connection speed can be set to a lower speed. Those that do not have a Fax Speed setting generally communicate at medium speed or lower as this was the past standard. Consult your user's manual for information specific to your model. Changing the Fax Speed Adjustment to a lower speed Follow the steps below.
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
  8. Try the fax again. If you continue to have problems faxing, contact your VoIP provider as they may have options to improve the ability to send and receive faxes over VoIP telephone service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 17, 2008
  • 63 Answers
SOURCE: hp laserjet 3380
did it work before??
if it did, then your printer has been damaged due to a surge in your phone line
Posted on Feb 03, 2009
Why is there no dial tone?
Connect a telephone in place of your fax machine. Listen for a dial tone. If you hear it, something is wrong with your fax machine connection.
Aug 15, 2015 | Brother IntelliFax-4100e Fax
I have dial tone but wont receive fax, can send out fax
Be sure thephone line is in the "line" plug, not the "ext" plug on the back of the machine.
Aug 22, 2014 | Brother Office Equipment & Supplies
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
May 01, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
