Question about Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ...
Ricoh Aficio SP 4110N error sc546 - Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ...
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
mimranon
  • 72 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
Posted on Apr 20, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
C546
change the fusing unit completely and put on the machine.
if the error appears again, enter the sp mode by
1,press the yellow key say three times and enter keys 107
2,press and hold the stop/clear key for say 5 seconds .the machine will take you into the sp mode.
3,put of the machine for about aminute and put it on again .
I believe when you follow this step well ,thie problem will be solved
GOOD LUCK.
Jun 11, 2014 | Ricoh Aficio 2045e 2035e Copier...
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
I had a functional problem sc 546 with my copier Ricoh 2022
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Ricoh Aficio 2022 Black and White Copier
How do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
Apr 27, 2010 | Ricoh Aficio 450 Copier
How i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
Oct 24, 2009 | Ricoh Aficio SP 4110N Laser Printer -...
Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ... Logo
148 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
