Question about Lenovo ThinkPad R500 Notebook
My lenovo r500 doesen`t charge or i think it is charging but when i take the charger off it shut down in 5 minuts what do i have to do?
  • 51 Answers
SOURCE: my laptop doesn't shutdown
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Posted on Dec 24, 2008
myjosh007
  • 530 Answers
SOURCE: my lenovo it keeps shutting down
hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
Posted on Feb 21, 2009
  • 2567 Answers
SOURCE: I have a new battery
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
Geekman
  • 32281 Answers
SOURCE: My Charger no longer charges
To problem could be a faulty power socket on the laptop, please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Posted on Sep 12, 2010
prashant2012
  • 1127 Answers
SOURCE: If the battery is fully
Hi
Battery is not charge bcoz this already charged. please don;t over charge your Laptop battery this is harmfull for laptop
Posted on Jun 04, 2011
My Lenovo thinkpad R500 shuts down without warning
Check over temperature. Is the air way clear of dust and fluff? Is the fan and radiator clear of fluff?
Aug 20, 2016 | Lenovo ThinkPad R500 Notebook
Why wont my Lenovo A2109A-F charge?
Lenovo has their trouble shooting for this at their web page.
http://mobilesupport.lenovo.com/us/en/products/tablets/a-series/a2109-tablet/documents/HT100036?tabName=Solutions
here is their brief info.
Please follow the steps below to check your battery.
What can I do if the battery does not recharge after the power adapter is connected?
  1. Check if the charger's indicator is on. Check if the charger's plug is fully inserted.
  2. Check if another standard battery can be recharged in your device.
  3. For some devices, you need to charge the battery for 5-20 minutes or until the charge level is 3% or higher before charging information can be displayed.
Note
  1. Different versions of the operating system may have different menu option names.
  2. Different versions of the software and features are available for different device models.
Jul 28, 2014 | Lenovo ideatab A2109A 9inch NVIDIA Tegra3...
Automatically shutdown, overheating, not charging
Not holding a charge is either a bad battery or a bad charger.
Overheating and shutting down is quite common.
1. Overheating can be caused by the cooling air passageway being clogged resulting in little or no air movement.
2. It can also be caused by a bad fan on the heat sink.
Both are easy fixes.
#1. Clean the airway with a can of air.
#2. Disassemble the laptop and replace the cooling fan.
Apr 22, 2014 | Lenovo Computers & Internet
Works fine on battery or charger with battery removed ,add battery and it quits in 5 minutes
Your battery could be old, therefore doesn't hold any long term charge.
Every time you add the battery it probably doesn't charge 100 percent therefore it discharges within 5 minutes, shutting down your laptop.
Apr 20, 2013 | Computers & Internet
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
My laptop doesn't shutdown
Dec 23, 2008 | Lenovo ThinkPad R500 Notebook
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Lenovo ThinkPad R500 Notebook Logo
221 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
