How to wire a dimplex lpc heater - Heating & Cooling
3 Suggested Answers
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK...
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
May 24, 2011 | Dimplex CS3311 Compact Heater
I need a new flame generator drive motor / spinner for my Dimplex Model No. 6901050100
what kind of on off switch do i need ,has one black wire and one white wire?
Oct 14, 2010 | Dimplex DS5598 Mid-Size Heater
Wiring diagram for Dimplex wall heater Model 6100770000
Jul 16, 2010 | Heating & Cooling
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
Dimplex baseboard heater wiring
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
319 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
