Question about Briggs & Stratton Garden
Briggs and Stratton pressure washer will not start. I have a 6.75 hp pressure washer that is only a year old. when I pull cord it turns over but does not start. I changed plug and checked it, I have spark when pulling. I have 40-50 psi of compression when pulling also. gas was drained and is brand new. it was working fine last time it was used. I have tried starting it without the water line or spray wand hooked up and no difference. After about 10 or 15 pulls, can smell gas when I am trying to start it, so I assume it is getting gas any ideas???
    Sergeant:
  • 316 Answers
Hello dave, the problem is compression to low,you need 60 to 130 lbs to run engine,check for blown head gasket,or bad rings,or a stuck open valve,hope this helps,,
Posted on Feb 22, 2012
  • davis5173 Feb 22, 2012
    so I should have 60-130 psi when I am pulling the cord?thowing do I check for a blown head gasket and valve? do I need to take engine apart and piston out for that?
  • pamabell Feb 23, 2012
    hello, is the engine a over head valve type,or flat head ?need to know what kind of engine you have so i can provide the proper information,,
SOURCE: Engine dies when wand trigger is released
Re-kit the unloader.
Posted on May 05, 2009
  • 384 Answers
SOURCE: can get no water flowing to the spray nozzle
Most likly the sliding nozzle valve is not fully down or up. I have found after the nozzle lay about for some time they get stuck from water scale. It took two persons pulling and pushing on the valve to get my to operate again. It worked for me.
Posted on Jun 11, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
sr6248
  • 66 Answers
SOURCE: Briggs and Stratton pressure washer will not spray
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Posted on Jan 30, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
Can a pull cord be replaced on a briggs & stratton 2300 psi gas pressure washer
yes take the top cowling cover off that houses the pull start normaly 4 to 6 bolts around the lower edge of this & you can pick this cord up from most diy stores or tool rentle firms just be carefull when the cowling is off that the cord spool/pully will most likely be under spring pressure unless the cord as broken completley hope this helps
Aug 16, 2014 | Garden
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Pull start won't pull. Engine was running then stopped. Now the pull cord won't extend
First. Turn off the water....Release all of the pressure off of the hose and pressure washer. Try and pull again. If it still won't pull check to see if there is oil in the engine. The engine may have locked up.
Feb 12, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
I have a 2500 craftsman power washer with a Briggs and Stratton engine. I used it about a month ago and it worked fine. Took it out yesterday and I could not pull the rope to get it started. I took out the...
It sounds like the pump is seized. Make sure any pressure has been released by pulling the trigger on the gun. Sometimes this will allow you pull the cord. If the pump is seized, a new pump would be in order.
Jun 15, 2010 | Briggs & Stratton Garden
Pull cord stuck on my pressure washer.
Need to remove assembly to find problem.
Mar 10, 2010 | Briggs & Stratton Garden
I have a Briggs and Stratton power washer Quantumpower 5hp water driver series 1750 PSI 2.0 gal min model # WGV1721 . I got it used and it was always a bit hard to start but always started. Pull cord...
Spray well with WD-40 or similar, and take a small chisel, on it's edge, and hit hard enough to allow chisel to dig in to head of screw, making a "V" like slot in the head, then angle chisel slightly and start tapping in direction of loosening(counter clockwise.) Once it loosens enough to get a pair of visegrips attached to head, use them, and spin them out. Make sure you replace them with new screws.
Jan 08, 2010 | Briggs & Stratton Pressure Washer...
Garden Logo
889 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
