Question about Samsung Cameras
Camera battery back up broblems
Battery not in long life
Mirror jammed up on Pentax
it will ceratinly be some matter with the batteries othrewise the settings may be faulty.......
Oct 13, 2008 | Pentax Cameras
Hello, I have a broblem with my super steadyshot, i get an error message:turn the power off and on again,,, help me plz
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Apr 19, 2011 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I have to change batteries in my Canon A710 after 5 - 10 pictures, what can be the broblem and how to fix it?
Buy the best quality batteries, but NOT the highest mAhr ones. They are designed for long usage for low drain applicaions but may not be able to deliver the high currents required by digital cameras. 2100-2400mAh is said to be best. Also, use a good quality charger that can discharge and slow recharge to reconditionbatteries. I recently bought a Maha charger and some Imedion batteries. Now my camera works as it should. (previously it lost the auto-focus after a few shots). A bit expensive but cheaper than a new camera!
Dec 26, 2010 | Canon PowerShot A710 IS Digital Camera
I took some photos andwheni connected to laptop they wern't there why?
camera does not show that the included battery for Camera in what could be the broblem whether the battery
Nov 28, 2009 | BenQ DC C500 Digital Camera
My camera is not turning on sometimes for a minute or so and than it works just fine so i returened it an d im having the same broblem with the new one why
Sounds like weak batteries.
Replace them or recharge them.
Keep in mind that batteries will discharge even if the camera isn't being used.
Crat
Oct 25, 2009 | Cameras
My Nikon coolpixs230 wont let me use the flash lamp just keeps blinking
change the battery by using 2100 mh battery ur broblem will be cured
Oct 19, 2009 | Nikon COOLPIX S230 Digital Camera
Maxxum 7 (analog) - won't turn on
Apperture base plate set needs replacing or there is a short in the camera ( camera dropped or acid leak ? ) . Especially the first broblem can be sorted only by trained people with some experience.
May 06, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
What causes bad battery life?
Bad battery life has a number of major causes: The primary causes are: Selection of the wrong battery chemistry or type for the camera used Extremely power-intensive use of the camera A damaged battery (probably the least common cause of bad battery life) The way in which the camera is used is at least as important as the battery chemistry selection in influencing battery life. The highest power-usage modes in any digital camera will be video and live preview. Thus, heavy users of these modes will see the shortest battery life. Other significant power consumers are the strobe, zoom motor, fill flash, and the image LCD display. For longer battery life, use these modes only as necessary.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Cameras Logo
12 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
