Question about Frigidaire Refrigerators
Having found there is no defrost timer on my frigidaire rlr1450 could my problem be the thermostat . on saterday the fridge ran all day and froze everything , switched it off overnight , on sunday it ran all day and never got cold
  • John Tripp
    John Tripp Feb 23, 2012
    Thanks For The Rate! JT
  • Frigidaire Master
  • 4,655 Answers
Yes your refrigerator could and most likely has a thermostat problem. Thermostats go bad in several ways, by not sensing the correct temperature, not working at all or sticking on until fresh food section becomes a freezer. Although I cannot find a Frigidaire Model RIR1450 in the US database that does not mean there is not one worldwide. Your refrigerator does have a thermostat most likely behind the control panel inside the fresh food section, Thanks Sea Breeze
Posted on Feb 23, 2012
Testimonial: "hi jt most grateful for your help.sorry about typo should have read RLE1450.will try new thermostat cheers"
catriver
  • 878 Answers
SOURCE: Fridge not working
Speed, If your model number begins with 596. This is made by Amana with the Kenmore name. Look at your defrost thermostat that sits on the evaporator, see if its bulged. If it is it's more than likley your problem. Part number 12001937. Your heaters should be calrod and seldom fail. Advance the refer into defrost by turing the mechanical timer clockwise until you hear it click and see if the heater comes on. Should find the timer under the control panel, should be a slot you can use a screw driver to turn it. If the heaters don't come on you can temp. by pass the bi-metal by simply cutting it out,connecting the wires and putting it into defrost again. However, it must be replaced. This is a safety device. If the heater now comes on, it's your bi-metal. If they don't come on with the bi-metal by passed, check for 120V at the heater connection. If no voltage, its your defrost timer. Careful in there your working with live voltage...Catriver post back.
Posted on Sep 07, 2006
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
tomsat69
  • 219 Answers
SOURCE: Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
Posted on May 20, 2009
Kenmore fridge, 59665932403, Froze up.
Could be an ice buildup behind the fan, in the air passageways or around the fridge thermostat.
Could also be that the DEFROST thermostat needs to be replaced.
Sep 09, 2016 | Kenmore Refrigerators
The fridge part is too cold causing the food to freeze and the temperature knob not working... out of warranty
sounds like a defrost timer or defrost thermostat issue u can check with a multimeter, the timer can be checked with a sml flat head screw driver inserted in the tiny slot at center and turn slowly till u hear it click once not twice, u will then turn on the defrost timer. this will give another 10 -15 days before it will be all froze up agin. if the defrost timer does not come on after trying this then u may have a bad defrost thermostat, of course u also want to check the cold control knob and the cold control vents are working properly
Jan 14, 2015 | Refrigerators
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
My Fridge started getting war and the freezer part was real cool i unplugged it for a day plugged it back up and it started working 2 days later it stopped again this time i took panel off the back and...
  • Well I can say one of the components responsible for defrost has failed -defrost timer, defrost heater or the defrost thermostat.
  • Unplug the refrigerator and pull the back wall off of the freezer.
  • Now unplug the defrost and the thermostat.
  • Get your Ohm meter out and test for continuity across the heater and the thermostat.
  • No continuity on the thermostat means that needs replaced and the same for the heater.
  • If both of them parts test out OK then you need to replace the Defrost Timer.
  • One of them is bad guaranteed. You want to make sure that there is some fresh ice build up too after cleaning it all off. This insures that which ever component that might be bad is verified messing up again per the ice. Then do the testing.
  • Thank you for using FixYa.
Regards, Tony
Jun 18, 2011 | Frigidaire Side by Side Refrigerator 23...
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Fridge is freezing up. not going thru defrost cycle
it is one of these 3 parts..
one, defrost heater,
two, defrost timer,
three, bi-metal or thermodisc.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Refrigerators
Frigidaire Model number frs26znh defrost not working?
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Jul 23, 2008 | Frigidaire FRS26R4A Side by Side...
Kelvinator fridge/freezer problem
It could be a thermostat but is more likely to be a defrost problem. If it freezes up within a short space of time I would suggest contacting a fridge guy who should be able to diagnose either the defrost heater, defrost thermostat, defrost timer or thermostat. Hope this is of some help.
Sep 14, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
309 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
